Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Why sound option is hide in bios ? - Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
    President:
  • 1,851 Answers
You have to enable this device through the bios settings. Usually it is in the "Integrated peripherals. Go there, locate the line about audio device and enable it using enter and the scroll up - down keys. Save and exit. Reboot the system and check the results.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Nov 08, 2010
I have an Acer 3610 laptop that wont boot up, im able to get into the setup, but it still wont boot up
From BIOS remove the option for hiding the startup information and write down the messages that you see on the screen.
Feb 28, 2011 | Acer Aspire 3610 Notebook
How to hide nokia 2690 clock
go to menu
click on settings
click on date and format settings
select date
select first option(date on standby screen)
click on hide date
Dec 04, 2010 | Nokia 2690 Cell Phone
T6522 with ATI XP EXpress 200 and comes up at v=75hz out of usable range for the moniter. Is there a F2 BIOS setting that returns the video settings to default even with the external PCI-E ATI card....
Try starting windows in safe mode? This should force the settings to 256 colours and a better refresh rate. If not, you'll have to borrow another monitor temporarily and adjust the settings.
To avoid the problem recurring, you should be able to set a checkbox which says something like "Hide options that my monitor cannot display".
Mar 06, 2010 | Computers & Internet
I don't want my friends knowing when I'm online to chat. How do I remove this so they don't know I'm online
Any chat application there will be a option to hide your availability, even you are logged in. Select go offline/hide/away option to hide your availability to chat.
Revert back for more assistance.
Feb 06, 2010 | Computers & Internet
Hidden files shown aoyomatically on startup
are you wanting to hide a few files? or you can right click each file ..go to properties and click HIDE that should work
May 26, 2009 | Microsoft Windows XP Professional
Laptop is giving murmuring sound
The murmuring sound is in all probability a Hard Drive noise... I had a similar problem and the solution lies in the BIOS.. at startup press F2 or the Del key to load into BIOS... in Bios you will need to look you way to an option for the HDD devices.. In my BIOS I had a option for an acoustic quiet mode which stopped the sound eminating from my hard drive
Note that all BIOS versions are different... If this does not solve the issue then please post the make of your laptop along with the BIOS version
Feb 12, 2009 | Lenovo Computers & Internet
Cannot insert columns in excel spreadsheet. Comes up with error cannot shift object off sheet
This error message occurs if the following conditions are true:
  • The option Nothing (hide objects) is selected in the Display options for this workbook section in the Excel Options dialog box.
  • You create an object, such as a cell comment, in any cell in a column.
  • You try to hide the column to the left of the column that contains the object, the column that contains the object, or all the columns to the right side of the column that contains the object. Or, in some cases, you try to insert a row or column in the worksheet.
There are two ways to fix this problem.
Method 1:  Temporarily toggle the option from "Nothing (hide objects)" to All In Excel 2007, temporarily toggle the option from Nothing (hide objects) to All, and then insert the rows or columns as needed. To do this, follow these steps:
  1. In the upper-left corner of the Excel window, click the Microsoft Office button.
  2. At the bottom of the menu, click Excel Options.
  3. Click Advanced from list of options on the left.
  4. Scroll down to the Display options for this workbook section, and then click All under For objects, show:, and then click OK.
Notes To use the keyboard shortcut to toggle this selection, press CTRL+6.
If these steps do not let you hide rows or columns or insert rows or columns in Excel 2007, try the steps in method 2.
Method 2: Change the position property of the object to Move and size with cells To work around this issue, Excel 2003, Excel 2002, and Excel 2000, change the position property of the object to Move and size with cells. To do this, follow these steps:
  1. If the object is a cell comment, select the cell that contains the comment, right-click the cell, and then click Show Comment or Show/Hide Comments. Note This makes the comment visible.
  2. Move the pointer to the edge of the object until the pointer changes into a white arrow with four small black arrows on the pointer. Then, click the object to select it.
  3. In Excel 2003 and earlier version of Excel, click <object name> on the Format menu. Note In this menu command, <object name> is the name of the object, such as "Comment" or "AutoShape."  In Excel 2007, click Format <object name>.
  4. In the Format dialog box, click the Properties tab.
  5. Click Move and size with cells, and then click OK.
  6. If you want to hide the cell comment again, right-click the cell that contains the comment, and then click Hide Comment.
  7. Follow these steps for each object in the affected column as described in the "Cause" section. When you hide the columns, you do not receive the error message.
For more information, visit the Microsoft Knowledge Base article: http://support.microsoft.com/kb/211769
Nov 06, 2008 | Computers & Internet
Asking
Hi Mykk
If you are using Microsoft windows then follow the following steps to hide any files and folder:
1. Right click the file or folder that you want to hide
2. Go to Properties
3. Now in the Attribute Section (Below the size of files or folder)
4. Now You'll be able to see two check box option i.e. "Read-only" & "Hidden".
5. Now check mark the Hidden Option in Attribute Section.
6. Click Apply Button.
7. Confirm the option to apply settings to Subfolder & files(This confirmattion is asked only if you are hiding any folder).
8. Click OK.
9Now you'll be seeing that the folder or file's color has been changed that means you have hidden file or folder Successfully.
10. Now Go to "Tools" in menu bar
11. Click "Folder options"
12. Go to "View" Tab
13. Now in Hidden files and folder optin below Select the redio box i.e. "Do not show hidden files and folders"
14. Click Apply button
15. Click Ok
To Unhide your files or folder follow the steps from 10-15, by just making changes in step 13.
You just have to select the radio box i.e. "Show hidden files and folders.
(Rate me after you have got ur solution)
-Thanx
-Romy
Aug 03, 2008 | Microsoft Windows Vista Ultimate Edition
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
87 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
