Question about Kenmore Washing Machines
Drum not spinning or draining. Making a sound like something is trying to run but cant.
    Genius:
  • 1,672 Answers
Check the power. If your Kenmore washing machine does not operate at all, you may need to replace defective or blown fuses or reset a tripped circuit breaker. This is done by moving the lever to the "Off" position and back to "On."
  • Examine the lid switch to see if it is defective. A malfunctioning switch can prevent the machine from operating or spinning. The switch can be found on the inside close to the door frame. Some models also have a special "lid-switch" fuse close by the lid switch within the control panel. A blown fuse will not allow the washer to fill with water.
  • Unclog the drain line if the machine is spinning but not pumping out water. If the problem still isn't fixed, the pump may need replacing.
  • Look for a broken pump belt or frozen water pump pulley if the machine does not spin or pump water. Test the pulley by disengaging it from the appliance and physically turning it. It should rotate freely.
  • Determine if the motor coupler or belts are broken, which could prevent the washer from spinning. Failure to spin also could be the result of a worn clutch, a malfunctioning drive motor, an improperly shifting transmission or a worn or "seized" spin bearing or basket drive. These problems also could keep a washing machine from agitating.
  • Find the source of a leak by checking the washer's air gap, inlet spout and rubber tube. Replace any items that are cracked, worn, deformed or disengaged.
  • Test the motor coupler, water-inlet valves and the drain hoses if your clothes are wet following the spin cycle. Replace these parts as needed.
  • Hope this might help u out!
  • Posted on Nov 08, 2010
    Duet dryer is making a humming noise when cycle starts a d during
    whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
    Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
    Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
    if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
    Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
    My LG front loader washer stops in the middle of it washing with the error code LE. For some reason or another it sounds as if a screw is loose in the drum or something in or near the drum is off cause it...
    "Lock Error"
    The fault code suggests that the lead that runs to the door interlock switch is faulty, has come off or is loose (Probably the latter by what you describe). I can't inagine how this intermittant error could be linked with what sounds like an item stuck in the drum.
    For the item in the drum, I have sucessfully removed screws and the like by thoroughly draining the machine then turning it onto its face, supported by enough bricks or other items to allow me to have the door dangle open. Gently spin and rock the drum back and forth and let gravity do the work. It doesn't always work, but it often does.
    Jun 28, 2011 | Washing Machines
    Have put a wash on today but drum won't empty, have no idea why this has happened?
    There are many reasons why it won't drain 1 the pump has gone. 2 is something is blocked in the pump. 3 the drain is blocked so won't drain. To see if it will drain turn machine on put on spin and press start if it still won't drain but making a sound like it is trying you need to pull out machine and check drain hose and drain for blockages. But if pump making no sound then the pump has probably gone and needs replacing.
    Sep 20, 2010 | Hotpoint First Edition WMA20 Front Load...
    Washer makes a steady thumping sound
    Could be coin in pump hitting blades...Try pump only no spin this will discount the drum ....Check filter if you have one.
    Apr 08, 2010 | Washing Machines
    WASHING MACHINE WILL NOT DRAIN OR SPIN .ALSO MAKING A SCREECHING NOISE WHEN IN USE AND WHEN ITS TRYING TO DRAIN OR SPIN AND SOME OF THE WASHING CYCLES DO NOT WORK ALSO WHEN IT TRY`S TO DRAIN OR SPIN THE...
    There might be a wire or something stuck in between the two tubs. If you go down to where the hose hooks onto the pump, you might be able to reach in and grab it. Plus there is stuff maybe in pump as well.
    Jan 13, 2010 | Washing Machines
    My washing machine got to the spin cycle but didn't drain water
    prolly cuz you didnt check your pockets first and either change or a set of keys fell out
    Aug 15, 2009 | Washing Machines
    My washer has benn making a sound once in a while like a wine today though it sounded like something was stuck in the drum or like rocks in it now it just hums during the spin it fills up washes but doesnt...
    If you might have got the sharp sound every here and then, tub might be imbalanced.However, if that's intermittent and sound is only during spin, more likely something caught in the drain pump making that noise.
    A generic solution how to clean drain pipe :-
    http://www.youtube.com/watch?v=6XIsK3W_Qcg
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Aug 12, 2009 | Washing Machines
    My hotpoint washer dryer wont spin. it is making a hunnimg noise when i try to make it spin.. also i turned it off and the door released so i could take my clothes out okay but they were soaking wet! i...
    It sounds like you have a problem with your spin/agitate motor or gear assembly. The drain is open it works by water pump and by centrifical motion. Opening thr drain duct shouldn't help anything. It really needs to go in to spin cycle to drain water. As far as it not spinning, you can buy replacemnet parts for the spin/agitate motor and gear drive, or belt drive if it is belt driven..
    Aug 07, 2009 | Washing Machines
    Washer doesn't engage the drum
    a ratcheting sound generally indicates some object (wire of sorts) tried going down drain but cant make it out but motor not turning drum over is something else, to check drain remove lower cover and open pump cleanout also feel the rubber hose from bottom of tub to pump to see if a object is in it. take hose off pump to clean out hose. if this is older duet check nut on rear pulley and tighten..
    Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    88 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
