Question about Electrolux Washing Machines
Electrolux time manager washing machine front loader - can't locate manual, have error message appear towards end of cycle - Error message - "E20" Can press stop/start button and cycle completes, but keen to know what it means!
blueextc3221
  • 15935 Answers
SOURCE: E20 error on Kenmore front loader. The water is
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
ginko
  • 19396 Answers
SOURCE: problem
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Posted on Oct 15, 2008
ginko
  • 19396 Answers
SOURCE: washer front loader
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
  • 11 Answers
SOURCE: electrolux Front Loader 7 Kg Error
From the manual E20W Problem with water draining
Posted on Feb 08, 2010
My Electrolux front loader machine is showing EHO in the display, it won't move off it no matter which program I try to display, can you please help me?
The power supply is failing and needs to be replaced but first try the steps provided in the link below. Washing machine displays error message EHO EH0
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 17, 2018 | Electrolux Washing Machines
Electrolux front loader EFLW417SIW that will fill & run for 3 minutes then the time remaining goes to 1 min. And turns off. I have power cycled / unplugged the machine.
Heater problems abort the wash cycle and end the program. May be faulty heater. Does machine drain and spin on spin only cycle? check pump if not - or motor.
Oct 25, 2017 | Electrolux Washing Machines
My Electrolux Front Loader stops mid cycle and then resets back to the start! It cannot finish a load?? There are no error messages being didplayed!
This may be a circuit board problem whenever it tries to reverse spin or drain some of the water...
what type and how long a cycle ....or does this happen with all cycle options?
Apr 15, 2014 | Washing Machines
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 26, 2009 | Samsung WF337AA Front Load Washer
Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
Nov 01, 2008 | Washing Machines
Electrolux Front Loader 7 Kg Error Message E20
Sep 14, 2008 | Electrolux Washing Machines
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
1,032 people viewed this question
Top Electrolux Washing Machines Experts
tom wright
tom wright
jimorris77
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
