Capacitors i am trying to match capacitors from an integrated amplifier one is 63v 18000uf
  • 2,071 Answers
Ccghvhjuhgugyfvhv
Posted on Jun 20, 2008
  • 1,512 Answers
Hi waveydavey1
You can get your caps from Farnell Electronics. Check this out They are world wideand reasonable price, great service. The 63volt versions are not as easily got these days. But you should be able to match something up from these guys. If they are the wrong size of problems getting them to fit... there may be more options.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 19, 2008
Why one chaneel not through equal sound?
One of the possible reason could be electrolityc capacitors in power stage.Every chaneel has 1 or more capacitors the value of woch is probably 10 000 mf/63v - check them out
Apr 29, 2014 | Yamaha AX-396 Amplifier
Sansui A200 amplifier dead right channel
Usually is a capacitor or diode blown open up the amp and look for any burnt marks on the motherboard
Feb 07, 2014 | Sansui Audio Players & Recorders
Bose lifestyle 5. Display is erratic when playing cd or radio.
Change capacitor C19 (33uF 63v) next to the dispaly. This capacitor goes leaky over time, and causes ripple on the display which makes it dim or even dissapear completley. Also worth doing all the capacitors near to C19 while your there just in case.
changing C19 worked for me. Some people even up rate the capacitor to 100v, but 63v id the manufacturers reccomended.
Aug 23, 2010 | Audio Players & Recorders
Toshiba 27A33 horizontal lines at top of screen
the problem is in vertical section of ur tv.. a filture capacitor 100mfd 63v or 47mfd 63v must be changed in vertical section
Mar 25, 2010 | Toshiba 27A33 27" TV
Tv not switching on Sansui SV2918, replaced faulty PTC and trans D2449 for lopty switching
all the transistors ,& capacitors i.e 47mfd 63v or100mfd 63v must be changed before u on the tv. if 300v is not coming to middle pin of d2449 then 4.7ohm resistor(fusible) may be gone
Mar 24, 2010 | Televison & Video
No power in NAD c350
Hi...
Have you checked the rectifier diodes / bridge rectifier . Most DMMs have setting where you can test for forward voltage drop on a diode
0.300- 0.800v depending on the type. If it reads nothing , swap the meter leads.
Also check the leads coming from the power transformer and see if there's continuity. THey will read low value ohms
Apr 26, 2009 | NAD C350 2-Channel Amplifier
Vintage capacitor
The closest substitute I could find is a 19000uF/75V from here. Of course you could also try the original parts manufacturer ELNA America Inc.
  • 5770 Warland Drive, Ste#B Cypress, CA 90630
  • Phone number: 714-761-8600, 800-700-ELNA
  • Fax number: 714-761-9188
  • Email: mail@elna-america.com
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 01, 2008 | Audio Players & Recorders
Help - I have the same Fault!
Normally DC BUS FAULT is fixed by replacing C14 and C10. C14 is the 100uf/63V and C10 is 2200uf/16V. They are located between the heat dissipator and the logic board near transformer TX1.
Mar 12, 2008 | Powerware 9120 UPS System
 Grubhead
Grubhead
