Question about Akai LCT2701TD Television
Need help finding an Akai LCT2701TD Power Supply Board Assembly
Hi! I'm trying to find the Akai LCT2701TD Power Supply Board Assembly and I can not seem to find it anywhere. Would anyone know of any websites or stores that this can be purchased at? Thank you!
  • Jc Ma Sep 05, 2008
    I have a problem on my power supply. I dont have an output on the cold side, but I got a output on the hot side. I replaced some bad parst but still dont work. Would you kind enough if you can provide me with schematic or and voltage test port. thanks for your support.
  • Anonymous Dec 22, 2008
    Akai has the part (MLT166A) but doesn't sell direct to consumer. Good luck finding a technician.
  • 2,326 Answers
It seems like there are not many of these service parts available anymore. The only way to get your LCD working again will be to repair it.
The repair involves changing the defective parts to restore the LCD functionality.
If you need more info, you can write to jah2mil@hotmail.com
Posted on Jun 16, 2008
LCT2701TD has no power, but the red light is blinkig
Well, the 5vdc standby power supply is working since you can see red light, but the rest of the power supply may not be working due to shorts or bad circuits in the power supply or in the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 07, 2010 | Akai LCT2701TD Television
AKAI LCT2701TD no power, no flashing light? Would the problem be the same as those with a flashing light or do I look for something different?
Hi
The flashing light is actually a code indicating an area that may be defective. With no light at all, I would assume something is wrong in the primary of the power supply or a major component has completely shorted thus causing the primary to stop working. Find a reputable repair person. Good luck
Apr 14, 2010 | Akai LCT2701TD Television
Akai lct2701td, flat screen tv won't turn on.
Oh Dear. I had the same problem!! The Akai televisons are not well engineered-meaning that they tried to put too much in a little package. The problem is that the power supply is malfunctioning"supposedly". But I believe that the sad truth is that the whole motherboard is malfunctioning. I can suggest a few TEMPORARY solutions but they too are not guaranteed to work!
1. Bring the tv to a repair shop and tell them to check the power supply. If it is faulty -have it exchanged and it will work for <2 weeks.
2. Literally "bend" the television in multiple directions to find a sweet spot where the screen turns on.( wait for the diode tu tur green before doing this) this will slightly bend the motherboard in hopes of agitating it to turn the screen/bulbs on.
I am terribly sorry that you too have this ridiculous problem!!!!!! :-(
Good Luck!!! I am crossing my fingers for you!!
Jun 10, 2009 | Akai LCT2701TD Television
Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 26, 2009 | Akai LCT2701TD Television
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Akai LCT2701TD
Unplug your TV for a while and see fi you are getting the same issues after you plug it in. If it works after, then you have an overheating issue with the power supply or main board.
Let me know if you need further assistance.
Oct 30, 2008 | Akai LCT2701TD Television
Akai LCT2701TD Won't turn on. Red light in front blinks.
There is a high power supply failure rate on these LCDs. The power boards are not longer being manufactured or not easy to find.
Write to jah2mil@hotmail.com for more info.
Sep 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
May 14, 2008 | Akai LCT2701TD Television
Red light still flashing
you also have to replace the 2 resistor on bottom of the board they are 10 ohms each they are surface mount 1/4 quarter watt each they are next to z3, also have to replace the 3 caps. I have fixed 4 units with the same problem this must be obviously a design issue since many of these tvs have the same problem.
hope this helps
Feb 16, 2008 | Akai LCT2701TD Television
Televison & Video Logo
682 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
