Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung HC P4752W Won't turn on, flash
My Samsung HC P4752W has the following problem: When I press the button on the remote to turn it on, it makes a little melody, shows some moving lines on a light background, then there is a flash of different colors and then nothing.
Here is a video of the current situation.
Could you tell me what the problem is and what I should do?
Thank you
  • cayennehorse Jul 10, 2008
    My TV is a 65" Samsung rear projection. It is 4 years old. Two years ago, the convergence board (with the STK's) went out. One morning the focus went out whack. I changed it myself (easy) and the problem went away. Last week, almost the same thing you filmed happened to me, except it does not go as far as getting colors on the screen. It just beeps, the red LED blinks and then the TV dies. I had noticed that during the past month, the TV went into that autofocus adjustement mode by itself, when I switch from the VCR to the DVD, etc. Never did that before. I just bought another convergence board, and will replace it tonight. I will let you know what happens.
I HAVE A JVC BIG SCREEN THE SOUND WON'T COME ON WHEN I GO TO THE MAIN MENU AND GO TO SOUND IT WON'T LET ME GO TO TURN UP THE SOUND
Posted on Nov 12, 2009
OOps!! I forgot to post a follow-up message.
It was the convergence board again. I am at my third one. Thank goodness it is easy to replace.
Posted on Oct 27, 2008
Did you try removing the board? If yes, you have to wires mixed up on the boards. You will have one on the Main board and another on the sub. They are black sockets. I had the same problem when I was repairing mine.
Posted on Oct 23, 2008
  • grixsil Oct 23, 2008
    Another thing you can check. Open up the back of the TV and turn it on. You will see the neck of the tubes glow really bright. If it does glow bright be careful as you might burn out the heaters in the tube and then its beyond repair.
  • Samsung Master
  • 8,617 Answers
Unplug the 3 wires that go to the convergence yoke and see if your set will power on, then let me know.
Posted on Jun 19, 2008
Tv won't turn on light blinks on front
can u help my tv wont turn on samsung hcp4752w
Oct 25, 2011 | Samsung HC-P4752W 47" Rear Projection...
My tv is severley un focused
Not possible.Try website like Remotes.com to buy an exact remote to the original remote.
Jun 24, 2010 | Samsung HC-P4752W 47" Rear Projection...
How do you get into the service menu on Samsung hcp4752w
I dont remember it exactly but ..if your TV is on then Press Standby and then press Info + Enter + Menu + Standby to turn on..you will get the service menu on screen.
Just alter the sequence of info + enter + menu to info + menu + enter or something.
hope it works
regards
bhavin
Apr 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
We have a Samsung TV Model #HC-P4752W OCT 2004 SN 392XA50454L THE TV WILL NOT TURN ON. A RED BUTTON COMES ON BUT NO GREEN LIGHT WHEN YOU PRESS THE ON BUTTON ON THE TV. HOW CAN I GET A MANUAL FOR THIS...
You can get the service manual for your model at the following link and they will help assist you in troubleshooting the set froo free . They email the service manuals out within minutes.
http://servicemanuals.vstore.ca/
Jul 11, 2008 | Samsung Televison & Video
Convergence issues
if youre having convergence issues with your samsung HC-P4752W you need to replace both convergence ICs numbers STK392-010 they are available at the following link and they provide free instalation instructions with pics so you can do the repair your self and they also give free tech support in case you need extra help. Its an easy repair takes about an hour from start to finish, Changing the convergence board wont help as the Convergence ICs are located on the sub deflection board and thats about 400 to replace the board compared to 50 to replace the ICs. Heres the link.
May 12, 2008 | Samsung HC-P4752W 47" Rear Projection...
Tv wont turn on after fixing convergence problem
Check the pins with a strong magnifying glass to make sure they are solderd correctly with none of the pins bridged with solder, then recheck all the wire connections to make certain they are correctly hooked up.
Apr 16, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752w
If you have any electronic background, the best thing to try first with this TV set would be to locate the convergence board and unplug the power plugs going to the board. Try then to turn on the TV set, and if it does turn on, turn it off right away! That will tell you that the convergence board is shorted and causing your problem. If the set still will not turn on you will need to trouble shoot the power supply board. If you have no electronic circuit board experience, this is not the job for you to attempt, play it safe and call in a trained tech. good Luck
Jun 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
679 people viewed this question
Henry  Thomas
Henry Thomas
