Tcl 14175. the button for security locked was pressed many times leading its permanent locked. when plugging it to the electric/power source, the standby mode is seen or automatically switched on while the manual functional buttons (tv, menu, volume, channel) remained unfunctional. our tcl 14175 tv lost its user's manual and remote control sensor. it has been 15 days already since its security lock was accidentally pressed. my email add is demoiselle21@yahoo.com. thank you so much.
premtech
  • 934 Answers
SOURCE: how can i get my tv to stop automatically changing to menu screen?
slapshot,
What you have there could be one of three possibilities. Micro, eprom or tact switches... Tact switches are the small contact switches behind the buttons you depress to turn the volume up and down or change the channel. Sometimes these small switches can become contaminated or breakdown due to corrosion. What we call in the industry a windex syndrom, because the older crts on some models had the swiches exposed just below the lower ridge of the cry where when cleaning the screen windex could drip down onto the switch and cause the corrosion to begin.
Eprom is another likely suspect. This Ic is responsible for storing an array of information including customer settings and other logics convert what the eprom stores into electronic pulses for any number of fuctions. For example press the volume down on your Tv and the eprom has the information to show you the volume bar, the level the volume bar was last set at and the increments at which you are reducing it realtime.
The Micro is another possibility. It acts like a traffic cop engaging various circuits to do or not do something according to a preset list of conditions. Timers, looking at a particular input or yes even bringing up the menu is tasked through the micro controller Ic or micro for short.
The fact that you can eventually get the unit to operate suggests that something in the logic circuit is failing and will in all likelyhood continue to do so until eventually it doesn't work at all...
Posted on Nov 14, 2007
SOURCE: TV controls not working
ARGOS SELL SPARES FOR ALL REMOTE CONTROL DEVICES ON THE ARGOS SPARES SITE. PRICEY BUT WORTH IT!
Posted on Dec 08, 2007
JigSaw007
  • 157 Answers
SOURCE: OSD menu locked
When the OSD is locked, pressing the menu button again and it will take user to OSD LOCK menu. Press (+) to unlock and allow user access to all applicable settings.
Posted on Aug 12, 2008
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
  • 1632 Answers
SOURCE: plasma tv frozen or locked and remote and tv buttons dont work
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Diagram of TCL-14175 I want to repair my Tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Televison & Video
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
I have problem model TCL-14175 I replace ic 8 pins 44608P40 but still unstable power supply
You've replaced the main system control memory IC, I assumes. If so, an adjustment called, memory initialization, should be done after replacement, or, the newly prepacked IC do not work. If you wish to get more details about this, check this link. http://electronicshelponline.blogspot.com/
Oct 08, 2013 | Samsung Televison & Video
Tcl-14175 power supply unstable
Check and replace damaged component/s at its main power supply regulator section circuit. Check all solder terminals, for any loose soldering. If you wish to get more details, check the site linked here.
Selecting the view option, either to Mosaic / Timeslide, can be selected by the dropdown list, at the top left of the display window, will make surf easy
No input signal on monitor screen
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
Mar 16, 2011 | Computers & Internet
My tv is a tcl brand model tcl-14175 i accidentally on the child locked.can I have the child lock code for my tv?please
my tv is tcl model ( t1436a ) , lost my tv's remote controller , please give the model number of remote controller
Sep 24, 2009 | Tvone TV-207 Television
Tv tcl-14175 no sound on channels but ok on audio video mode
Hi
The first problem was always standby mode.... get back the original eprom IC 24CO8WP in to the PCB, then find the original remote control of you TCL Tv tcl-14175 then you power On In the Remote control while your TV is in Standby mode! then you see your tv is going ON... Because your unit is in Child lock Mode....
thanks!
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
Child lock code -5- has appeared.
Here is what worked for me.
Turn left to light on, then off
on/off (light)
on/off
on/off
(4-5 times)
do not run through the complete cycle of options
just to the light and back off.
Ken
Aug 16, 2008 | Neff U1661 Double circotherm super...
Bosch maxx dryer
The manual for our Maxx WTL6500 says to press and hold the Start/Stop button for 4 seconds. "The child safety lock can be released permanently using the Menu button." In our case that means press Menu 3 times then press Change to set the lock on or off.
HTH
Jul 02, 2008 | Bosch Axxis WTL 6307 Electric Dryer
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
