-   I see the same thing. Only on SD images though. HD, Menus, and PIP look fine... I've heard the solution is to replace the digital board, but you need to copy the hex values from the old board to the new board. Trying to find out how to do that.
-   StickyC
my rca wide screen is having problems turning on .... it blinks 1 time pauses and then 9 time.. it...
(More)
my rca wide screen is having problems turning on .... it blinks 1 time pauses and then 9 time.. it seems to only work when it hot , once on it works great.... but once turned off takes many times to turn back on ...
I just moved my 42in. Toshiba rear projectiom Tv from my basement to the upstairs and now my...
(More)
I just moved my 42in. Toshiba rear projectiom Tv from my basement to the upstairs and now my convergence is off. The red tube cross is low on the manual adjustment and will not go up to the other colors.IT moves up and down,but it is starting about 3in.below the cross hairs. Any help?
Mitsubishi WD-62327 fan noise. The noise is not coming from the easily accessible fan mounted in the...
(More)
Mitsubishi WD-62327 fan noise. The noise is not coming from the easily accessible fan mounted in the center of the back of the case. It sound like it is coming from the inside bottom of the box. Is this the cooling fan for the power supply or ballast? The whining sound is intermittent. Is this a reasonable problem for an engineer with a good set of tools or should I call a professional? Does anyone have a good site where I can download a service manual (preferably wothout providing a credit card number!). I have had great success troubleshooting and repairing this set with the outstanding information provided onthis site! Your help is very much appreciated!
I pushed a button on the controler and every thing is black and white,wow do i get the color back...
(More)
I pushed a button on the controler and every thing is black and white,wow do i get the color back on?
