Hi, I am trying to recharge a friends' MIO P350. I have the appropriate adapter and have plugged it in to the power socket but the recharge light will not come on and battery power is still diminishing. Any ideas?
  • juggernau569 Nov 08, 2010
    We figured the same thing. Thanks heaps and we'll try it.
  • 6,993 Answers
it is possible that the adapter is defective, that's why it won't recharge the battery. The reverse might also be the case, that is, the battery might be defective.
Now, borrow an adapter and test it with the MIO P350 or the adapter on another MIO P350. This will reveal whether or not the adapter is good, so that we can focus our attention and other possible cause of the problem.
But first, you need to confirm if the adapter is working or not. Because presently, it looks as if the adapter is bad.
Good luck.
Posted on Nov 08, 2010
Hi,I want driver for Mio P350,I have windows 8.1
Automatically get recommended drivers and updates for your hardware
http://windows.microsoft.com/en-us/windows7/automatically-get-recommended-drivers-and-updates-for-your-hardware
Dec 19, 2014 | Mio P350 Pocket PC
Does anybody have a start up code for mio m419 lm
Go onto the Mio.com website and contact section under support. Send a message with the serial number requesting the key.
Jun 12, 2014 | Mitac MIO P350 PDA POC PC+ GPS SAT NAV...
Power problem
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 09, 2013 | Compaq Computers & Internet
Rdrhow to find recharge componets on a215-s4807 motherboard?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 14, 2012 | Toshiba Computers & Internet
Probook4530s not recharging. powercord or recharging device problem
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 15, 2012 | HEWLETT-PACKARD Probook 4530S
Battery not recharging
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 18, 2009 | Toshiba Computers & Internet
My HP pavillion ZD8000 laptop will not operate on mains power. To recharge the battery the machine has to be upside down. There would appear to be a loose connection wher teh mains adapter plugs in to teh...
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 10, 2009 | Computers & Internet
My mio p350 was playing up. it then hard reset it self. it came back on line and was working for a few minutes then stalled. i soft reset it and now it will not come back. it stays on the first page...
Mio P350/550 Hard Reset 1. Turn off the pocket pc (on/off button ).
2. Push the joystick button up (to the screen).
3. Turn on the pocket pc.
4. keep holding on the joystick button for 30 second.
Oct 30, 2008 | Computers & Internet
Mitac Mio 168 sound - adapter 2.5 to 3.5 mm jack
I believe there is something wrong, its a normal stereo socket.
I use differend 3.5 to 2.5 adapter (standard, from the shelf)without any problem to connect an FM Stereo-Transmitter.
The best solution to connect your car radio, its wireless.
regards JK
Dec 09, 2007 | Mitac Mio 168 Pocket PC
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
