Question about Mitsubishi WS-65413 65" Rear Projection Television
I pressed A/V Reset by accident!
I pressed A/V Reset by accident and now the color is violet and yellowish green and the sound is on a completely different input. I have a Charter cable DVR box. The people at charter are NO help. What did I do wrong and how do I fix it? Thanks!
Emily
  • 927 Answers
Good Day Emil;
You did not break the TV it is okay. Try resetting the TV by unplugging it from the wall then back in after 4-5 minutes. If that does not correct your concern go into the menu and adjust device and color setting. Look for set up.
Good Luck, let me know if this was helpful.
Posted on Jun 21, 2008
My 62 in projection Toshiba tv, has not picture or sound, what can it possibly be? Please help.
please do the following. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | Toshiba 62HM95 62" DLP HDTV
My Toshiba tv has no picture or sound, it only tells me that the door is open.
please do the next test.God bless you
Jul 31, 2013 | Televison & Video
RU49NZ23 RED GREEN AND BLUE IN 3 D AND DID AUTO CONVERGE BUT NOW THERE IS SOUND BUT NO PICTURE
follow this steps and fix it. God bless you
Jul 31, 2013 | LG RU-60SZ30 60" Rear Projection...
Dull green screen
reset the TV and fix it. God bless you
Jul 30, 2013 | Philips 51PP9910 51" Rear Projection HDTV
I have this blob discoloration that is in the center of my screen. what could this be its a yellowish green color
Yellowish green colour is usually caused by a burnt blue LCD Panel or the light engine requires servicing.
Jan 15, 2011 | Zenith E44W46LCD 44" Rear Projection...
Color of picture on all channels in yellowish
Your optical block, also known as a light engine, is going out. I actually just had mine replaced today!!!!
Dec 11, 2009 | Televison & Video
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Blue violet ghost
did you just replace your lamp? your balance is probably off.
Jan 31, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
Dec 26, 2007 | RCA P52937 52" Rear Projection Television
Mitsubishi WS-65413 65" Rear Projection Television Logo
155 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
