Primera Technology Autoprinter, Bravo Se, 100-240VAC, InkJet Logo
Anonymous Posted on Nov 08, 2010
I have a Bravo SE printer at work, but when ever I print black it comes out a red/maroon colour. I've tried cleaning and religning, Ive taken the cartridge out and it looks fine. All of the other colours are printing fine. It's not that old and it says there is still 73% ink left. Please Help!!
Josh Whitehead
Level 3:
Genius:
  • Master 1,148 Answers
  • Posted on Nov 08, 2010
Josh Whitehead
Master
Level 3:
Genius:
Answers
1148
Questions
Helped
247270
Points
3024
Be sure to not only print an alignment page but do the head cleaning options on printer tools/properties,,should help,,or even correct ur problem
Testimonial: "Thanks, it didn't fix it, but the print that way looked perfect so I knew it was a setting issue. I changed some settings and it looks fine now :)"
Printer will only print purple
on a colour printer, black is mixed with the other colours. Try printing a black and withe photo and you always get a colour cast. If your black cartridge is empty or the nozzles are blocked, you get bad colour and fussy prints.
test all nozzles, like is explained in the manual.
Check, if you know how to do, if nothing fell in the printer, that is now on the print head. Sometimes just dust or paper scraps are picked up by the printhead, making it difficult for the printer to print a normal page.
2answers
My Lexmark printer X2690 will not align properly after I' ve installed a new colour cartridge I have taken the security strip off! please help
You could try to remove and reinstall your color cartridge again.Do a Clean Cartridges cycle.Then do an Align Cartridges cycle.
My mp-115c printer ive just replaced all the ink,fitted /cleaned correctly yet when i go too print something of the internet it only comes out in Black,no Colour.. WHY? Thanks
try clean heads, if more than one week without printing the heads ink dry.
NOTE:some internet sites, dont allow printing, so you can get the same results.
The red colour is faded. i'm trying to print out a photo which is fire engine red and it is coming out peach. the ink isnt low. ive cleaned the printer heads, and nozzle checked it. no difference. the...
Did you clean the printer heads manually with alcohol and a Qtip?
Also pop out the red cartridge, cover the hole and give it a good shake, then try again.
Chances are the red ink simply wasn't as "fresh" as the others.
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
COLOURS PRINTED DO NOT MATCH SCREEN COLOURS OF ITEMS
I would try cleaning off the nozles on your print cartridges. If that doesn't help, replace them altogether.
DCP-135C printing crooked
Hello! I need help!
My Brother printer - DCP-135C
I've changed all inks include the colours.
I able to print the Red, blue and yellow. But I can't print the Black.
I've tried pressed the cleaning option for many times.. Please advise some help.
Rgds, V
1helpful
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Will not print some colours
Rhis seems to be a printer Firmware problem, Nothing for it but to bin the printer and start again.
Top Primera Technology Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
