Question about Philips 50P8341 50" Rear Projection Television
Wont work turn power button on hear it juice up then power button flash six times please help
  • Philips Master
  • 3,459 Answers
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
Posted on Jun 29, 2008
Toshiba Satellite X200-LC3 no power. i bought new AC adapter but the laptop is not taking juice. no flashing lights. is battery fried that it wont take juice? motherboard issue? please help. This comp
It's either the adapter connection or the MOBO itself.
Anyhow try removing the battery and adapter press and hold the power button for 10 to 20 sec plug the adapter with out the battery and restart. Hope this works if not check the MOBO for jack problem
if battery is already charged try with battery alone. Also be sure adapter is compatible the right voltage IE 19.00, 18.00
Mar 11, 2014 | Toshiba Satellite X200-AA3 Notebook
My kp-57/65wv600 flashes SIX TIMES, PAUSED ABOUT 3 SECONDS AND BLINKS SIX TIMES OVER AND OVER! WE PUSH THE POWER BUTTON AND WE CAN HEAR WHEN TURN ON AND OFF, BUT NO IMAGE/PICTURE APPEAR. THANKS!
First off I would check your lamp to make sure it isn't burnt out. Usually the lamp door is on the backside of the TV. On my 2006 SXRD its on the right side of the TV just behind the buttons. Here is a link to a diagnosis page
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 30, 2011 | Sony KP-51HW40 51" Rear Projection...
My sony won't turn on. when I use the remote to turn on it flashes green six times, I hear a click and then it flashes red six time.
six times means the thermal fuse on top of the lamp tripped. Replace it and give it a good cleaning and it should work.
Feb 20, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The tv made a pop sound and now it wont turn on ans both green and red buttons are flashing ..please help
I had the same problem guys! This is what I did:
My T.V. wouldn't turn on. The standby light was flashing six times, then four, then seven...I called Sony and they told me to unplug it for a couple of minutes, then try it again...didn't work....BUT, I have found a solution:
Try unpluging your T.V. for 4 hours+, then turn it back on. Worked for me! It's called a "hard reset" by sony. I had my T.V. unplugged for the whole day though.
Aug 11, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Starting up Problems
I found it 2 min. ago. Ok here: while your ps3 is on hold the power button on the ps3 for you will hear one beep, keep holding it then when you hear the second beep take your finger off. Your ps3 should turn off. Now push the power button while holding your finger on it again, you will hear two single beeps, then a double beep, let your finger ago and a screen should appear with six options. Chose something like reset(or restore) file data or something like that and click yes, this wont do anything to your game/music/movie/etc. files but now your ps3 shall work.
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Tv not working
This fix may be of some help. www.magnavoxhelp.com
Jun 16, 2008 | Philips 50P8341 50" Rear Projection...
Camera wont turn on!!! i hear gears turning
Fuji Technical Support team website is the place to ask for further advice. But if the camera is more than a ear old - replacement is the only remedy.
Jul 01, 2007 | Fuji FinePix E510 Digital Camera
Sony KV-32HS510, worked perfect, turned on the next day and all I got is flashing red light.
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Oct 19, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Philips 50P8341 50" Rear Projection Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
