Question about Olympus Camedia C-760 Digital Camera
My Olympus c-760 seems to have developed an issue whereby the camera will take one, maybe two photos if I'm lucky, before it tells me that the battery is empty and turning itself off. I can turn it straight back on and go again for one or two photos, over and over, until the battery is genuinely empty. I have two batteries and the problem occurs with both, even when fully charged. I have tried using the firmware updater on the Olympus website but the camera appears to be too old. Any ideas? Is it worth getting the camera repaired or should I just move on and invest in a new camera?
    Genius:
  • 1,148 Answers
Check to see if anywhere on the camera there is a reset button,,check olympic website to see if ur model has option ,,if unable to find it,,,,also check to make sure your button is not sticking,,or jus not moving when u push it,,if that is the case,,turn it off ,,take batteries out,,take a little rubbing alcohol on a qtip,,put jus enuff to wer when you push down some squeeses out,,try cleaning button,,where a little gets down in there,,let dry,,turn on see if it helped,,
Posted on Nov 08, 2010
  • spanky791 Nov 08, 2010
    Unfortunately there is no reset button. When you say button, do you mean the button to take a shot? I'll try cleaning the contacts and see if that helps, I didn't think of that.
Olympus all weather 760 errors 5f08 5f0a 5e02 Blue error message lens will not retract makes burring sound help please
The sound your camera is making, is probably the slipping from the gears, grinding them down, because something is blocked. Even when you can't see any blockage. Please don't leave the battery in, to avoid more damage. Contact a certified Olympus repair centre, or visit your dealer with the camera.
Sep 17, 2014 | Olympus Stylus Stylus 760 µ Digital 760...
I have an olympus stylus 760. I cannot figure out how to turn on the time/date stamp...
While the camera stores the date (and a lot more) with every picture, it will not deface your pictures by scribbling a string of numbers across them. Any photo editing/cataloging program should show you this information. Depending on the program and printer, you can print this information on the image, in the margins, or on the back. For example, if you're printing directly from the camera you can turn on DATE under CUSTOM PRINT.
Aug 03, 2011 | Olympus Stylus 760 Digital Camera
Olympus MJU 760 Battery dies after a couple of
First step to trouble shoot. Connect a low voltage ohm-meter to the battery contacts inside the camera. Try to turn camera on. If you get a reading, write down the number of ohms. If possible, compare this with a brand new one, if store will let you. Or call the USA distributor. If ohms number is way low, you have problems inside the camera. If number is normal, the battery is no good.
May 14, 2010 | Olympus Stylus 760 Digital Camera
Can not instal an olypus camera
To learn about the new and free version (no serial number is required) of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
Jan 09, 2009 | Olympus FE-100 Digital Camera
Olympus Stylus 760 digital camera
Found a solution by looking at other websites and other comments. I discovered that if I went to playback mode and then to card set up and found 'format' as long s I ahd copied and saved the photos actually on the camera, I could click on format which would give me a caution message and then say 'yes'. This erases all the photos but cured the problem!
Jul 26, 2008 | Olympus Camedia C-150 Digital Camera
Olympus 760 error d;8234
http://www.fixya.com/support/t513228-olympus_760_error_d_8234
Jul 19, 2008 | Olympus Stylus 760 Digital Camera
Olympus FE-220 will not let me take pictures
I am having same problem. View is black/blank, digital shutter appears to work but not photo taken. Returning camera to dealer as this appears to be an Olympus manufacturer error.
Jun 13, 2008 | Olympus FE-220 Digital Camera
Olympus Stylus 760 problem
I just called technical support and they told me the camera has an internal problem. You have to call them if your camera is still under warranty and send it to a repair center.
Apr 29, 2008 | Olympus FE-170 Digital Camera
Replacing screen on Olympus IR-500
I would suggest this is not going to be a viable task. at any level You taking it to pieces and then finding replacement parts. Contact Olypus for advice My guess is that a 'repair' will be near the cost of replaceing the camera. Photo stores [such as Jessops here in the UK] seel Screen protection material. this is like a heavy duty self adhesive tape- which can be cut to size for your screen. That I suggest is a low cost fix.
Sep 27, 2007 | Olympus i:robe IR-500 Digital Camera
Olympus Camedia C-760 Digital Camera Logo
89 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
