Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
ACER AL1715 POWER SUPPY BOARD AR577 VP-583 TURNS OFF AFTER START UP
I HAVE AN ACER AL1715 17" MONITER THAT TURNS OFF AFTER A FEW SECONDS OF START UP. THEIR HAS BEEN A SOLUTION ON FIXYA OF REPLACING TWO CAPASITORS 680 UF,16V IN C152 AND C153 BUT I HAVE A AR577 VP-583 POWER SUPPLY BOARD AND IT DOES NOT HAVE C152 OR C153 NOR DO I HAVE ANY CAPACITORS OF 680UF,16V CAN ANYONE PLEASE HELP ME WITH THIS.
  • MIKECABRERA Jun 16, 2008
    THANK YOU
  • Anonymous Aug 10, 2008
    horizontal lines on left side of screen
  • 3 Answers
I have an Acer 1715 that also turns on, then goes dark after a few seconds. The capacitors on the AR577 supply/inverter board were good, but I replaced them anyway. There is a good write-up with photos at:
http://www.electronicrepairguide.com/acer-al712-lcd-monitor-repair.html
This shows the board nicely and capacitors for the 1712 Acer, which is very close to the 1715.
This didn't cure my problem, and after chasing signals, I believe the problem is a bad inverter chip. The SG6841SZ on the back side of the board is a 20 pin gull wing surface mount package that drives the FETs to switch voltage off and on to the high voltage transformer. I know the diodes and FETs work because it comes on. The transformer drive stops when the backlights go out, though the voltages are all there. The 5V drive signal from the control board is there, so the problem has to be the inverter, or all 4 FETs.
If I can get hold of the part and it fixes it, I'll post it here.
Posted on Jul 29, 2008
    Guru:
  • 1,342 Answers
Bad capacitors will usually be bulging on the top.
Acer Parts
Posted on Jun 16, 2008
Need to know what to replace on the AR577 VP-583 REV:1B power board for acer 22inch lcd
It doesn't costs much to try to change all the electrolytic capacitors on it, often it solve the problem.
Jan 27, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Power on , then goes off in a seconds
Hi:
Unfortunately, that symptom usually is caused by a failure in the power supply board , that is internally mounted inside your LCD monitor. It is possibly repairable, but usually it is about as cheap to get a new monitor.
Dec 10, 2009 | Acer AL1715 17" LCD Monitor
No signal on computer moniter
1. Check your cable
2. check your cable pins make sure there not bent.
3. Check your video card make sure its putting out the correct resolution for the monitor.
No signal is just what it is. You may have a bad cable,bent pin or video card is not operational.
Things you can try.
Hook it up to a diffrent computer
Check the pins on the cable.
Worse case would be the little board inside where the connector is could be bad.
Thanks I hope this helps
Dec 07, 2009 | Acer AL1715 17" LCD Monitor
After i open my monitor then after few seconds its turn black.model hp1702
. Please explain what you mean, after i open my monitor then after few seconds its turn black.model hp1702
Aug 30, 2009 | Acer AL1715 17" LCD Monitor
Acer LCD AL1916W
This usually means the Power Inverter board is going bad. If you're a bit savvy with tech repair, you can look up and order a replacement board - LCD inverters for MANY LCD models are available on ebay and amazon - they're relatively easy to replace. Just make sure the power is UNPLUGGED before to start taking apart the display!
Feb 13, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Acer al1715 main board is a problem
shop jimmy on E bay send him an email question
Jan 31, 2009 | Acer AL1715 17" LCD Monitor
Monitor turns off
Since the green light is going out the monitor's power supply could be the culprit. That popping sound is not good. I would replace the monitor all together.
Jun 03, 2017 | Acer AL1715 (Black, Silver) 17" LCD...
ACER AL 1912 19'" LCD MONITOR
I have the service guide for this monitor and the values for the R811 to R814 are the same: 1.8 . The mosfet is a 2SK2645. I will like to send the pdf file, but I new in this site and I don´t know how to attach a file due the only options that I see is a link, image or you tube clip.
Good luck
Sep 04, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Acer al1715
Failing capacitors in the power supply will cause this problem and it's fairly common accross all brands.
The parts are cheap, but the labour costs can be high.
If you cannot do this procedure yourself, and also understand the dangers of the electronics, then call several TV repair shops in your area to get a quote, you maybe surprised how much the price can vary.
Just advise them you need to have the capacitors on the power board replaced. It will help them give you a more accurate quote.
May 01, 2008 | Acer AL1715 17" LCD Monitor
Monitor keeps going blank at start up
This looks to be a power supply fault - the inverters for the backlights are built into the power supply (Delta Electronics, model no. ADP-40AF).
Aug 10, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
2,613 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
