Question about Hunter 30124 Air Conditioner
What does no ac power mean and how do you fix it
Acer aspire e1-532 battery led off when plug the ac adapter and does not power up
It is beyond what I can diagnose remotely, as it fails to power up even on just the AC adaptor, without the battery.
It needs a professional repair, which means opening it up to find out why it fails to start or even show a screen, which means no software fix can be done.
Feb 05, 2015 | Acer Computers & Internet
Ac compressor
When you say "fire" I'm going to assume you mean power. The AC compressor gets power from a large 12 to 10 gauge wire from the electrical distribution box; from a 20 - 30 amp fuse, up through the dash A/C controls including the thermostat, a low refrigerant pressure switch and electric clutch on the AC's pulley.
Any of these parts that have failed, opened or detected somethig wrong - will prevent the the clutch from engaging - to allow the belt to turn the AC pulley.
Check the easy stuff first like fuses. Use a test light to help trace the power to the point that it no longer is present. Make repairs as needed. If the pressure switch is not allowing power out, that means the refrigerant charge has leaked out to a level below what is needed to run. A simple recharge will fix this - at least temporarily. A large leak will cause the switch to open again and will require a repair of the leak before going any further. That's where it can get expensive. Locating the leak, accessing it and repairing or replacing parts is where the real expense lies.
May 30, 2013 | 1996 Mercury Grand Marquis
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
I have a Dell Inspiron 5160 Laptop that has been working decently for me for a while. I have always had issues with the laptop recognizing the ac adapter but usually been able to spend a few hours and...
Hi there!
First the problem that you were having with the ac adapter can be fix by just updating your computers BIOS.
Now for the computer not turning on try this, first remove battery make sure ac adapter is unplugged then press power button for 5 seconds after that put in battery and then press FN + POWER at the same time this triggers the diagnostic on your computer if it runs then just wait if it will give you an error message. If it fails then try to use just the ac adapter that means battery should be unplugged.
Hope this helps!.
Sep 06, 2011 | Dell Inspiron 5160 Notebook
My x box 360 will not turn on & the ac adapter box light is lit up red
If you are getting a red light on the A/C adapter then your adapter has gone bad and you need to get a new one.
Dec 22, 2010 | Microsoft Xbox 360 Console
Wont power from main but power up frombattery
Either the motherboard or the ac adapter might be ba. Make sure the outlet your plugging the laptop into has power first.
Once you verify that then try using the AC Adapter and see if that works. If it doesn't work and it only turns on from the battery for 30 seconds then you need to try a new AC Adapter and see if that fixes it, if it doesn't then its a motherboard issue at that point cause the means its not seeing the AC Adapter properly.
May 01, 2010 | Toshiba Satellite A135-S2386 Notebook...
Ac power low alert when computer boots up
It means your power supply is failing. If you need the computer, you should replace the power supply before it fails completely.
Apr 26, 2009 | Dell Dimension 8300 PC Desktop
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Hunter 30124 Air Conditioner Logo
236 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
