Question about Amana ADB1600AW Builtin Dishwasher
The display is flashing HO, what does this mean?
I was wondering the same thing. This is what I found:
The display shows "HO" or "Hd." What does this mean?
HO" or "Hd" means the dishwasher's cycle time is being extended while it is heating water. At certain points in the wash cycle, the dishwasher uses hotter water to ensure a clean load of dishes. If it detects that the water is not hot enough, it will heat it.
If you're seeing "HO" or "Hd" frequently, check the temperature of the water available to your dishwasher. It's best to do this at the sink closest to it, allowing the hot water to run until it reaches its maximum temperature before you test it with a thermometer. For best results, water should be not less than 120°F.
Posted on Dec 10, 2010
Ho to Fix fujifilm camera jx420 zoom lens ?
What do you mean 'Ho to Fix Fujifilm camera jx420 zoom lens?' What's wrong with it? You really need to add more
Dec 18, 2014 | Fujifilm Finepix JX420 Digital Camera
Sir Nokia 2310 open nhi ho rha computer per flash ic ki problem bata rha h kya kia jae
just give some heat to flash ic with some flux & try to flash it will be ok
flash ic ko thori si heat de kar dobara flash karo theek ho jay ga. yeh flash ic ka fault hota hay
koi bhi UFS programm flash k liye use ker sakte ho
best of luck
Aug 18, 2011 | Health & Beauty
Ok. I inherited my rangemaster 110 when I moved house. I've no manual but a digital clock with a bell, 2 strange looking things that I presume mean ho and oven, then a hand and a plus and minus button. ...
Most of these timers have 3 buttons, the hand and the plus and minus buttons. Try pressing the minus and plus buttons at the same time. The display should flash. Then adjust the time with the plus and minus buttons. If this doesn't work just try different combinations of pressing 2 buttons. If the timer is not faulty on of these combinations will work.
Feb 18, 2011 | Rangemaster Classic 110 Kitchen Range
Dishwasher is on and running a load. It is flashing HO??
The "HO" means it's trying to heat the water to the appropriate temperature before proceeding in the cycle. It's totallly normal, and can go on for 20 minutes or so... if you run your sink faucet to clear the line of hot water first, it will reduce the time it takes to heat the water
Apr 03, 2010 | Frigidaire Professional Series 24 in....
AWM8000 AF flashing and machine cut out, very
WHEN I PRESS START - HAS ALARM ON DISPLAY F AND H FLASHING AND TAP OPEN POSTER HAS THE FLASHING LED TOO. HO TO REPAIR IT.
MY NAME XUAN
Sep 29, 2009 | Whirlpool AWM8000 Front Load Washer
Kenmore model 587 - HO flashing - what does this mean?
It means the dishwasher is on hold till the water temp reachs 160 degrees to sanitize them nasty dishs Kimosabe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Dishwashers
"HO" flashes on display during washing.
HO, indicates that the dishwasher is using Hot Water. It is completely normal.
Mar 08, 2009 | Frigidaire Professional Series 24 in....
I want to know what HO means on a frigidaire dishwasher?
it means the water is trying to heat up and it is taking longer than normal. Check your hot water heater to make sure it is heating properly. Do not use hot water in other areas at same time ..ie: washer, shower, etc. The HO will disappear once the water is heated to the proper level by the dishwasher.
Dec 31, 2008 | Frigidaire Dishwashers
Error "HO"
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature.
Thank You Huum
Please remember to leave a solved rating before you sign off!
Dec 20, 2008 | Dishwashers
Frididaire dishwasher HO on display screen
If it is coming on during the cycle it means the dishwasher is heating the water. If it is after the cycle or the cyle is stopped it means it did not reach the proper heat temperature. As long as it is running through the whole cycle it is ok.
Jun 13, 2008 | Frigidaire Dishwashers
Amana ADB1600AW Builtin Dishwasher Logo
770 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
