Question about Dometic Rooftop RV Air Conditioner
Duo-therm 13500 btu
Do oyu know why my a/c keeps throwing the breaker. ok well i'll turn it on and it will run for a few hours and then throws the breaker. after it throws it i'll wait about an hour and then turn it back on and in like 5min it throws it again. we have tried almost everything. cleaning the filter, the drip pan, the coils, changed the breakers, put it on a seperate breaker, and cleaned all the componets on the unit itself. do you have a suggestion?
  • 828 Answers
First I would check the size of the power supply cord to the coach. To small a line will cause a voltage drop which in turn will cause the amperage to increase. Check the supply voltage to the system.
Posted on Jun 20, 2008
Fan runs but does not cool
Always take pictures first before you fix
anything, or take it apart. so you will know how to put things back
Aug 15, 2015 | Dometic New 13500 BTU Duo Therm Brisk RV...
Why does AC Duo-Therm thermost throw the breaker and needs set to approx 55/50 to run ?
`Try changing the breaker some times they get weak and will trip at start up. Also check for bare wire shorting out. Then check capacitor then fan motor spin blades to see if they spin easy and that bearings are not bad.. make sure all connections are tight with no corrosion. These problems show up more with short cycling then with long.
Jun 27, 2014 | Dometic Rooftop RV Air Conditioner
Duo Therm AC won't cut off with thermostat
Hi, sounds to me like the thermostat is at fault.You have done nothing wrong to it but cover it up. The t-stat is what controls it, turns it on and off. The only other thing that would keep it on all the time would be that the thermostat wiring could be touching together from the stat up to the unit. You might check that before replacing stat. I have seen this many times.You can start the unit and go up top and disconnect the stat wire and it should stop the unit.Then its either the wire or stat.Let me know what you find,
Sincerely,Shastalaker7
Nov 04, 2009 | Heating & Cooling
Throwing Breaker
you could have a couple of reasons.If you use an extention cord that is too small,If the circut is overloaded.Bad breaker,good luck!
Jul 08, 2009 | Coleman Propane Forced Air Heater...
Breaker turns off when air is turned on
The compressor has a short going to ground .when resetting breaker stand off to the side they can and do explode. you will need service. Tom
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Jun 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
May 13, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
119 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
