Question about Philips MCD515 Micro DVD Shelf System, 50 watts, Logic Tape Deck Shelf System
I have two Philips MCD515 Micro DVD shelf Systems, 50 watts, that were bought about three years ago. Both have recently stopped playing CD's. I heard one stop abruptly, while a CD was playing. I suspect a drive band may have failed. I have tried to remove the outer panels to check for this, but, after removing most of the screws, I still cannot get the box open. Is drive band failure normal with this model ? Can a replacement band be obtained and fitted easily ?
SOURCE: My DVD drive does not open
I suggest you may have accidently put another disk in your DVD drive on top of the one used previously without removing it first: I know, I did just that, and the teeth may now be sheared on the drive wheels which means it will probably need replacing with a new one.
To open manually, look for the tiny hole beside the Open/close button just under the drawer and insert a long slim steel probe which will activate a switch to open the drawer. (Have a look among your kitchen utensils, there might be something there).
Hope it works, but you may find you need a new DVD/RW unit, so have a look around in the New Year Sales and use the opportunity to buy the best you can find at a bargain price.
Raydot
Posted on Dec 20, 2007
Death-seed
  • 22 Answers
SOURCE: shelf stereo turns off by itself and stops working all together.
how loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Posted on Feb 05, 2008
  • 116 Answers
SOURCE: bought a 50 philips (50pfp5332d/37).
Take the tv off the stand and lean it against soemthing, take the stand to a hardware shop and find some bolts that match the threads inside the stand. I think that would be your best bet. Just dont lay the tv down, if you have ot put it in the box thats ok, I just dont want it to get broken while we hunt down some screws.
Posted on Dec 12, 2008
  • 85 Answers
SOURCE: Steaming function stop working
its just connected with a screws on the front flap that has to be opened to seperate it into two parts,and inside there is small black coil thats is connected to the wires that wires must be short so has to be replaced with another wires. do it carefully .take care.
Posted on Feb 26, 2009
  • 35 Answers
SOURCE: Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Posted on Mar 05, 2009
Philips mc235B/37 CD player no longers plays CDs. I get a "No Disc" error or an "Error" message. CD's often don'teven spin. If they do, they spin slowly, then stop, and start spinning in reverse before...
if you can see the laser then gentaly with a soft cloth wipe the lens
and then try
if that doesnt work then i recoment that you call philips and see what they say because it is slightly older than one year they might replace it for free
if not call the shop that you bought it from
May 09, 2010 | Philips MC235 Shelf System
I have a Philips model #FWM575/37 Cd/Tape/Radio combination player. It is only 3 years old and the CD portion is not working. CD starts playing, then stops and can't get any CD to work.
You may just get away with cleaning the lens of the CD player to restore it to normal, use one of the brand name makes of CD Lens Cleaners.
Jan 06, 2010 | Philips FWM575 Shelf System
Instruction book for a micro cd shelf system
not solved - but not going to pay for an instruction book when it should be a 'downloadable' item by sharper image
Dec 03, 2009 | Sharper Image SO330 CD Shelf System
My recently made music CD will NOT play in our Philips FW-R7. It will play on all our computers and DVD players. The message is "Wrong Disc." Other music CD we've made do play fine in the FW-R7.
This is common with burned cd's they have trouble playing in different sets. Do prerecorder cd's play fine in your philips? If those are having trouble also you could improve it's playability possibly with a cleaning of the opu. Optical pick up.
Jul 17, 2009 | Philips FW-R7 CD Shelf System
Philips mcd288 mp3 albums
There's a little bit of work involved, but what you should do is to record those tracks individually as folders, then transfer those to your DVD burner...accordianman
Dec 30, 2007 | Philips DVD Micro Theater Shelf System...
No sound while playing dvd/cd
sound muting circuitery prblem or sound swiching section problem can occure this type fault.sometimes it can be cd /dvd printed board problem.give it to qulifid technician .
nuwan.
Dec 12, 2007 | JVC FS-S77S DVD Micro Component Stereo...
Cd player says error
I had the same thing happen to mine, only after six years, After taking the top off, and looking at the inside, I realized it was the belt that had stretched out. I am still trying to find a place that sells replacement belts. I was able to get it to work by taking the belt out, cleaning it with a tissue and some rubbing alcohol, and putting it back in. you may want to look into the belt.
Dec 05, 2007 | Philips MCD515 Micro DVD Shelf System, 50...
Philips hts 6510 no disk prompt does not play dvd
Ok looks llike a lens problem..Try this
Get a lens cleaner CD with liquid..Put two drops of liquid on the brush of the lens cleaner..insert the CD in your drive and play it..If it plays fine otherwise you will need to replace the lens..Get it replaced rather..should run you about 25-50$.If you want to get it repaired give it for repair only in a Philips showroom..
Oct 15, 2007 | Philips HTS-6500/37 System
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
Philips MCD515 Micro DVD Shelf System, 50 watts, Logic Tape Deck Shelf System Logo
66 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
