Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
How can i open my new seagate 500gb hard drive?
  • 5,660 Answers
May be a little different, than the Seagate FreeAgent external harddrive enclosures I've opened up.
Here are for two styles;
1) Style one:
External enclosure sits on a hollow tube that ends in a base.
Turn the Seagate FreeAgent external drive over on it's top, base up in the air. The base is formed out of two parts made of plastic.
A flat part on top, and a cupped shaped plastic part underneath. (Shaped like a rectangular cake pan)
The rectangular 'cake pan' part has 4 feet on it.
The rectangular shaped part comes out of the flat base.
If you look close you will see a parting line where the two plastic parts meet.
A flat tipped screwdriver is used to pry the rectangular shaped 'cake pan' out of the flat top part.
Start in one area of the parting line, pry up a little. Move over, and pry up again. Keep going around until the rectangular shape comes out.
The flat part attaches to a hollow tube shape. Looking down there are three Philips head screws to remove. Removing them removes the flat shaped part of the base.
One on each outside edge, (Two total), one in the middle.
The flat part comes off.
Then you will see two more Philips head screws to remove. One on each side.
After removing the base, and the two screws listed above, the external enclosure comes apart in two halves like a clamshell.
The two halves have a parting line where a flat tipped screwdriver is inserted to pry them apart.
DO NOT insert the flat tipped screwdriver tip, in between the two halves of the case, more than the length of half the length of a fingernail!
It ISN'T an easy task to separate the two halves. You won't be using the external enclosure's case anymore.
Also watch your fingers! The plastic edges are S-H-A-R-P!
One half of the external enclosure's case has tabs that stick out along the edges of the case.
These are shaped like a square loop. The loop has a hollow space in it. A Female tab if you will.
The other half of the external enclosure's case has tabs, that snap into the square loops. A Male tab if you will.
The female square loops are plastic formed from the case, and can break easily.
After you open the case you'll see what I mean.
One half of the case removes. The other half has the Harddrive attached to it.
After you remove the case half, you will see a metal shield.
There are two long Philips screws that go down through the metal shield, and hold the Harddrive assembly to the other half of the case cover.
Remove them. Two on each side.
You now half to use your fingers, and a little brute force, and pry the Harddrive assembly out of the case half.
Metal shield and all.
You will see two wires, (Red and Black) that connect to the case half, and come up to a White connector that attaches to the Harddrive assembly.
Disconnect the connector from the Harddrive assembly.
Lay the case half aside.
You can now see how to remove the Harddrive from the rest of the assembly.
2) Style Two:
Shaped like a book, with one side having a taper, or slope.
I believe this explains it better than I could. It's a video.
http://www.youtube.com/watch?v=73jHstTFGFo&feature=related
CAUTION!!
I would NOT use a sharp bladed Knife!!
Use a butter knife, or a thin flat tipped screwdriver!
WATCH your fingers. There's No need to hurry, or use dangerous techniques.
Want you safe!
Post comments or additional questions in a Comment. (Believe upper right of your page)
Regards,
joecoolvette
Posted on Nov 08, 2010
4 Suggested Answers
SOURCE: New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Posted on Nov 19, 2008
bschilz
  • 2049 Answers
SOURCE: Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Posted on Nov 06, 2009
SOURCE: Seagate 500gb Free Agent Ex Hard Drive - Class Action siut
DO NOT buy a Seagate freeagent drive under any condition if it comes as a gift return it or re-gift to some one you don't like. Like so many others my 500GB external drive just quit working. Has only been plugged in about 6 times and then back into a cabinet to keep safe. In 10 years between 2 workstations 3 laptops and 4 external drives. The only drives that have ever gone bad are the Seagates and newer Maxators. I still have 4 Western digital drives that still work and get used in an external case for back up. They have never failed. Seagate should be responsible for data time and mental anguish.
Posted on Nov 15, 2009
My seagate goflex 500gb external drive is malfunctioning
First of all check for viruses in the above mentioned folder. This problem can also be due to faulty connection between your drive and your pc, please check the cable that you r using and try a different cable.
Nov 25, 2012 | Seagate FreeAgent GoFlex Desk 500GB...
External hard disk
As you are a seagate user so it would be advisable to try using this software to recover seagate sata hard drive. Just download it online for free trial.
May 22, 2012 | Seagate ST3500418AS 500GB 7200RPM SATA...
I have downloaded the files from my old computer to the Seagate hard drive. How do I transfer those files to the new computer?
Copy, Paste. Just choose what files you want to copy over, and WHERE you want to store them.
If I were you I would create a new folder on the desktop, right-click an open space, new folder.
Then highlight all your old files, right-click, copy. Open the "new folder", right-click empty space, paste.
Mar 17, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
My computer cannot recornize my seagate freeagent g0 500gb, cannot open it
Right click on My Computer, select manage/disk management. If your drive shows up there right click on it and select mark drive as active. Reboot and you should be good to go.
Jan 06, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi , I have 500GB USB ..i just been six months..
SEAGATE ('www.seagate.com') offers a one-year warranty.
Copy all your files (onto another disk, or onto DVD-writable disks),
and then exercise the warranty for SEAGATE to repair/replace it, at no cost to you.
Dec 27, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
Why i cant format my seagate 500gb potable hard drive, when format it in quick format its show an error that the hard drive not successfully formatted. what should i do? please help me, i need it asap....
The disk-drive inside the enclosure is "dying".
If the warranty still is valid, exercise the warranty to get it replaced, at minimal cost to you.
If the warranty has expired, open the enclosure, remove the disk-drive, and take the disk-drive to a computer-store. Buy a new, compatible, drive, and then "transplant" it into the enclosure, to "revive" your external file-storage appliance.
Nov 17, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
I have just purchased a Seagate 500GB Desktop hard drive
There is software preloaded on the disk. If you have AutoPlay turned off in your system, it won't start automatically when you connect the drive. Just go to MyComputer and open the drive and you will find a setup file there to install the backup software (I think it's called Launch.exe).
Oct 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have Seagate - FreeAgent Go 500GB External USB 2.0 Portable Hard Drive, I formated with MAC now is now detected by my PC. What should I do?
Open up the control panel with the drive connected, open administrative tools and computer management. Select storage and see if the drive is listed there. It will probably let you format it from there.
Oct 24, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500gb external hardrive cannot run after installed
yes , depending on which system you are using . this can be very easy. click on hard drive but dont open it right click go down to format and format it to ntfs . slow or quick format if nothing on.
Jun 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
234 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
