Question about Cyberhome CH-DVD 300 DVD Player
I've been using AV cables for it since I got it, but today I got component cables and a new TV. When I plugged the cables in to my tv it didn't recognize the dvd player, but when I plugged in the AV cables it worked just fine. Is it the player or the cables?
Configure the player to output Y/Pb/Pr to the TV. Make sure it's not configured to S-Video or anything else.
Posted on Nov 08, 2010
Is HDMI4 correct or HDMI1?
how many jacks do you have . I would think it will be 1 or 2
Feb 22, 2016 | Dynex Televison & Video
Dynex 32 in only shows black and white now
Black and White on a new setup would indicate you've plugged in AV or Component cables incorrectly. Match the colors up, be aware some Dynex models have AV connections on the SIDE of the TV. Don't just plug colors into random places. Failing that, check to see if your still inside 1 year manufacturer warranty or a best buy product protection plan. If not, seek out repair locally.
May 15, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
No sound, picture ok, volume nil
What cable u are using?Like a RCA AV component cable or a HDMI cable?Tries another AV holes in the tv,if use a HDMI cable tries another HDMI hub on the tv.Or replaced with it the new RCA AV component cable or a HDMI cable.
Feb 10, 2011 | Bush DVD2038 DVD Player
Hooked up hd cable to ps3 and tv, now have no sound
Be sure to check the cables. You may need to replace them.
Try the cables with another component, if possible.
Also, try using AV cables to verify that it is not the TV and to simply troubleshoot:
To get back to default AV settings:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it shuts off again.
Once you have verified that AV is working, turn off console, take out AV cables.
Plug in HDMI cable and turn system back on. Switch TV input to HDMI and it will ask you if you would like to use the HDMI cables, select yes again and verify.
If you cannot get sound, again, check the cables..
If new cables do not work, then your HDMI output is going bad, not from use rather normal wear and tear of the motherboard.
To get the best non HD picture, you will need to get some 'component' cables, rather than the standard AV (red, white, yellow).
Good luck
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
No picture are sound,have tried new leads but nothing
need a bit more info. Do you have TV set to the correct input that you have the Wii plugged into. What type of AV plug are you using is it standard yellow, white and red plugs or are you connecting with component cables that have extra green, blue and red cables as well as the standard ones. You need tv set to component input if using the component cables.
Dec 31, 2010 | Nintendo Wii Console
Ok I have a xnox 360 and when i plug the color coded cables into the color coded tv inputs i turn the channal to video 2 and i hear sound but i could not see anything? sooo what do i do?
Are you using AV or component cables?
*Solution for AV Cable*
Check to make sure the cable is fully plugged into the port. Having it even just slightly out of the socket will render no video. If this doesn't work, try plugging it into a different port on your television to make sure the port isn't bad. If you still have no video - the video part of the cable could be bad and you might need a new cable.
Also make sure that if your cable has BOTH component and AV connections available that the switch at the end of the cable near the Xbox is set to "TV" as opposed to "HDTV"
*Solution for Component Cable*
Also check to make sure that all the video connections are fully plugged in. If even one of them isn't plugged in fully, it could render no video. Also make sure that you have them properly plugged in to the right color. If you're just quickly connecting it to the back of the TV without proper lighting, it can be easy to confuse the blue and green connections.
When using component, make sure that the switch at the end of the cable near the Xbox is set to "HDTV" as opposed to "TV".
Jul 09, 2010 | Microsoft Xbox 360 Console
NO sound and NO cable signals
Is your tv connected to your cable box through HDMI, AV, or component?
_____________________________
If its through HDMI then your cable carrier needs to load updated frimware in your box to communicate properly with your 2005 tv. The firmware loaded in your cable box needs to be "reverse compatible" for first generation HDMI from your 2005 tv. If your using AV or component hook-up and there's no sound then re-check all of your audio settings within the tv's menu. Also recheck the cable-wire your using and proper input/output ports.
ON your dvd player, is your tv connected through component, AV(rca) or HDMI?
If its through "component" then you need an extra audio cable to and from the DVD and tv.
May 07, 2008 | Akai LCT2060 Television
Ps3 tuning
Hello!!
Try connecting the PS3 with the different cable ... i mean the problem may lies with cable ... So give atry once ..
Jan 03, 2008 | Televison & Video
Cyberhome CH-DVD 300 DVD Player Logo
351 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Level 1 Expert
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
