Question about Westinghouse WST1550 Wired Deluxe Upright Vacuum
Broken Belt for Fantom Crosswind 600XL
It seems I have vacuum cleaners that now need belts replaced.
I cannot find my manual for my Fantom Crosswind 600XL and Fantom is now out of business.
Researching online it was replaced with a Westinghouse Wired Deluxe Edition (Westinghouse WST1550)
Can anyone walk me through changing the belt myself.
Or, where do you go to get it repaired. Zip code is 48081
Thank you for any assistance you can give me.
  • Anonymous Mar 29, 2009
    How to change the belt on Model TH52 - No manual
    Problem Solver:
  • 8 Answers
Hello, your Fantom vacuum will take a Panasonic U vac belt, to replace it, their are two screws in the back, one on each side of the back of the housing, take out the two screws and lift off the top hood, and the vac belt is on the side, remove the brush roller clean any debis away, put the new belt around the metal motor shaft first then around the brush roller, and pull down into the housing, make sure it locks in evenly, then turn the roller to make sure it moves freely. then put the hood back on front first, hold down and put the screws back in, in the back. now your ready to vacuum. Any question or more help I can give, please call 1561-848-3387 Thank you, Teresa.
Posted on Aug 10, 2010
I need a new belt where can i buy one and what size is it
wallmart or target sell belt or you can go to a vacum cleaner co. go on line to fantom an they will give you places near to you to buy it with that serail no
Sep 04, 2009 | Fantom Vacums FM625H Vacuum
How do I change the fantom fury belt?
Fantom Vacuum site. Find the Model #-usually
on the back of this model,type it in and you can
read and look at diagram .Good Luck.
Belt ordered at Totalvac.com.
Dec 29, 2008 | Fantom Vacums XT450K Upright Vacuum
How on God's green earth do I open the Fantom 12 amp to fix the beater brush belt?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=787057
Generic problem for all Vacuums
Posted by rickiman on July 15, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are probably 2 ways to get @ the belt, usually there are screws, clips or levers on the bottom side of the bottom plate and once they are removed you should be able to get @ the belt, if not then the top cover should come off and then you should be able to get @ the belt. At this point you should be able to get @ the belt to change it. #2. you can always refer to your Fantom owner’s manual for additional information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 15, 2008 | Vacuums
Change my belt on a fantom vacuum model number is f1420gf
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766591
Change my belt on a
Posted by sylvester021 on Jul 10, 2008
Change my belt on a Fantom vacuum model number is f1420gf
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt change on the Fantom is to remove the bottom plate by undoing the screws, clips or levers, then cut off the old belt, remove the brushroll on the pulley side and place the new belt on the pulley side and replace the brushroll. Then use a belt puller or screwdriver with a hook on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line. The replace the bottom plate and you should be fine. The recommended belt change on a vacuum with a flat belt is every 4 to 6 months for the best cleaning and always use the genuine belts for the Fantom. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Changing A Belt on Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=656349
Changing a Belt on Vacuum
Posted by cnjk on Jun 08, 2008
Can you give me directions on changing a shark Euro-Pro UV219CS vacuum belt?
Thank you.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Shark vacuum cleaner belt is a side driven belt and you need to remove the bottom plate and remove the belt and place the new belt on the pulley side of the brushroll and make sure the ends are the same, insert the brushroll and then use a belt puller or screwdriver with a bend on the end and then stretch the belt onto the motor pulley and the track it in a straight line, replace the bottom plate. If you need further assistance please fee free to contact your local vacuum cleaner dealer in your area. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Belt is broken
Most upright vacuums will have 2 screws on the bottom of the vacuum. Remove both screws and snap off bottom cover to get inside of the head. Remove old / broken belt and slide agitator off from the head unit. Stretch new belt with both hands then place around the agitator and pulley coming out of the motor. Place the agitator back into place (there will be some resistance from the new belt, but that is common). Put back on the bottom cover and place back the screws. You should be all set then. Hopefully this helps.
Mar 14, 2008 | Fantom Vacums CW600 Upright Vacuum
How do i open my cleaner to put a belt on
Thank you for your fast reply, I took off the screws on the lid and replaced the belt with no problem
Westinghouse WST1550 Wired Deluxe Upright Vacuum Logo
138 people viewed this question
Top Westinghouse Vacuums Experts
Kevin Getz
Kevin Getz
Tom Chichester
Are you a Westinghouse Vacuum Expert? Answer questions, earn points and help others
