Question about Canon EOS Elan IIE 35mm SLR Camera
The camera back button requires power to operate and as the electronics seem to be fried button pushing doesn't open the door. So is there a manual access way? thanks
  • 747 Answers
I had a Canon Elan IIe and I don't recall having to have electronics to open the camera back.
Make sure you have a battery in it, turn it on look at the LCD panel and see if it has film in it.
If so you should be able to push the "mid roll" film rewind button located on the back left side it shows a film canister icon. Once the film has rewound into the canister release the back with the mechanical latch found on the left side (while facing the back of the camera) just push it down and the back will pop open. Those cameras are pretty darn good and the only thing I've seen friy the electronics is using an "old" type flash on the hot shoe and that takes the flash circuit board and melts the thing. I'd expect the camera battery is dead and you can't rewind the film back into the canister.
Posted on Dec 01, 2010
My GMC Yukon door not opening
This appears to be a fairly common problem on your vehicle 2 seperate occurences the electronic locks will not operate and also the mechanical latch not operating both resulting in an inoperative back door condition. It seems the only way to open the door is to remove back door panel and manually operate the latch mechanism and then find why it will not operate normally for instance the linkage no longer being attached to latch mechanism or electronic connector not making connection both have been found to be common in gmc yukons
Aug 08, 2014 | GMC Yukon Cars & Trucks
Doorbell doesn't work
It seems your doorbell transmitter got wet and corroded the contacts.
These push buttons are not sealed at all and thus will let rain, snow etc. eventually corrode the electronics.
Solution: Find a new push button on eBay.
Cheers
Feb 26, 2013 | Desa International White Wireless Plug In...
Lexus 2007 RX350 trunk door doesn't open or close from key, trunk button and power door button
OPEN MANUALLY AND CHECK THE STRUTS PS. IF WHEN YOU OPEN IT AND IT GOES BACK DOWN THAT'S YOUR PROBLEM
Sep 25, 2012 | 2007 Lexus RX 350 FWD
Garage door opener (Sears 139.664700) has power but will not operate when button is pushed
Could also be the start capacitor in side the garage door opener box, check for electrolytic driping out for signs of a bad capacitor...
Jun 21, 2012 | Home Security
I just had a power outage. My garage door was open during the whole afternoon. I pulled the red trolley emergency cord and pushed the door down but I couldn't get it closed (locked). Why not?
IF THE OPENER IS IN THE OPEN POSITION THERE IS NOTHING TO LOCK IT IN THE CLOSED POSITION.
YOU CAN UNPLUG THE UNIT AND PLACE A VICE GRIP ABOVE A ROLLER ON THE TRACK. THIS WILL SECURE THE DOOR UNTIL POWER COMES BACK ON - DO NOT LEAVE THE UNIT PLUGGED IN - IT COULD BE DAMAGED BY A POWER SURGE WHEN THE POWER COMES BACK ON (ALL ELECTRONICS IN THE HOUSE SHOULD BE UNPLUGGED) ALSO IF YOU FORGET AND PUSH THE BUTTON THE VICE GRIP WOULD CAUSE THE DOOR TO COME OUT OF THE TRACK, MAKING YOUR CURRENT ISSUE SEEM SMALL.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Communication to the opener fails. The little green light on the door opener goes out. It eventually returns and then the door will work again.
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Aug 02, 2009 | Liftmaster, Chamberlain, Sears Door...
2002 Toyota Sienna power sliding door stopped working
it seems like this is the motor that operate the sliding door...it might just be the switch on the door where you push the button if that isnt the only button that cant operate what it is suppose to operate...the motor will be locted inside the door
Jul 01, 2009 | 2002 Toyota Sienna
Probelm ejecting the dvd from my Hitachi GX3100A
If you go to the Hitachi website, you can download the product manual for your camcorder there.
These are the instructions for opening the dvd door.
1 Press down the DISC EJECT button once and
release it.
A few moments after the ACCESS/PC
indicator blinks, the cover of disc insertion
block will open.
2 Gently open the cover by hand fully until it
stops.
This is the link for the owners manual search: http://www.hitachionlinestore.com/survey/manualsearch.aspx
Hope this helps.
Apr 29, 2009 | Hitachi DZ-GX3100A DVD Camcorder
I dont no how to put the batteries into my mercury cyberpix s-555v digital camera. and i need help and it doesnt seem 2 turn on or i dont no where is the power on and off button. can u help 4 free. thank u
look at the battery and then the camera,matching up the positive and negative,close camera door,the on button is the little button on the left at the top of the camera,hope this helps you
Nov 26, 2008 | Mercury Electronics CyberPix S-550V...
Canon EOS Elan IIE 35mm SLR Camera Logo
83 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
