Question about GE Nautilus 24" Built-in Dishwasher
Dish washer has no water.
I never used my GE Nautilus dishwasher. Today I started my dishwasher and I can hear a motor running but no water fills the dishwasher. I water vovle is open. I will appreciate it if you can help.
  • avongirl101 Jun 20, 2008
    Have the same problem on a brand new Quiet Power one machine... and then it won't shut off, I have to unplug it
    Sergeant:
    Champion:
  • 330 Answers
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Posted on Jul 06, 2008
Dish washer just doent start to wash when i turn it to start?
pls check 1)water is filled in the tank. 2)check wash pump jammed.if any bearing is failur this will persist.
Jun 03, 2010 | GE Nautilus 24" Built-in Dishwasher
I just got this used and would like to know do you hook it to hot water or cold when installing it?
Hello. Definitely hook it up to the hot water under the sink with a shutoff valve. Then when using it always run the water in the sink until it is hot before you start the dish washer.
Mar 13, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Built-In Dishwasher
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Sep 17, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher problems
The washer may be attempting to run dry. Many times on these washers, a person may open the washer and then go to another load. The washer gets stuck with a dry pump until the timer tells water fill valve to open. Easy test. Start on regular cycle ,slowly advance the timer. it will click until you here the fill start and water will fill until.....
Jul 06, 2008 | GE Dishwashers
GE Nautilus 4800 Dishwasher/Shuts off/ No water draining out
It may be the motor start capacitor or the motor or the wiring to it. Some units have a built-in switch that shuts the unit off if the motor doesn't start turning after a short interval. However, if it drains it usually means the motor runs enough to pump it out. These units usually stop draining when the fill switch opens at the lower level.
Nov 29, 2007 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
290 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
