Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
I need a kit for water ,pipe plastic for get water in my frige
    President:
  • 1,891 Answers
This is a standard 1/4 in line and can pb purchased at any hardware store. but do use a better grade of shut off on water line . one that you drill instead of self persing . type . a 1/4 in hole supply in man water line is a better suply than the small line persing type ..mm
Posted on Nov 08, 2010
Fluidmaster instructions
Turn off water at valve. Drain tank. Remove fill line that goes to bottom of tank. Remove large nut from underneath tank holding in old fill/float valve assembly. Clean area around hole in tank above and below. Get large black washer from kit put onto bottom of fluid-master pipe (lip side down). Place fluid-master into hole from top of tank to check height. Top of fluid-master valve should be even or just a bit below top of tank. To adjust hold head of fluid-master and turn pipe ccw to lengthen, cw to shorten. Once adjusted put into tank. Using large flat nut in kit tighten to tank, making sure its centered in the hole, no part of the float touching the sides of the tank, and that the small nipple on the side where the small black hose will attach is facing towards the overflow pipe. Make it nice and tight, but don\'t break it.Then re attach water supply line you removed earlier, hand tight only. Place pipe clip onto top of overflow pipe (funny looking plastic clip with metal piece attached). Attach small black hose to fill valve nipple on side of valve, other side to funny clip. You may need to cut it shorter so it doesn\'t kink. Tun on water and adjust float if required. Level should be 1/2" below top of overflow pipe.
Aug 23, 2014 | Home
Zel 67W Zanussi refridgerator
new frige smell? not rotten food. something to do with motor maybe stale water in pan. how do i clean it. i see some screws do i need to unscrew something to get to pan. where can i put bleach or clorox? have had for 1 day and the odor is annoying. like a plastic smell. don't think its wiring shorting or anything like that but who knows. landlord replaced my leaking frige with this used one. magic chef model# mcbr1020w
hy60yhur r1340 LBP
huayi compressor 1005057074
Aug 15, 2013 | Electrolux Refrigerators
Have a GE Frige # TBX18SAXPLWW. Large amounts of water collect on inside, bottom of frige. Back wall wet from frige/freezer temp control locate at upper most rear wall of unit. What could problem be?
When in defrost mode, frost is melted and the water is directed to a tray at the rear bottom of the freezer. A tube is connected to the bottom of the tray so the water is sent down the back of the refer to evaporate at the bottom.
The tube gets clogged with gunk, water backs up and freezes. Then, at the next defrost cycle the water has no place to go except into the refer interior.
Unload the freezer, remove the bottom plastic plate, let the ice melt, unclog the tube, put everything back together and you're good to go!
Aug 08, 2010 | GE Refrigerators
My amana frige leaks at the bottom, it is a bottom freezer frige, I moved it lately because I am laying laminate floor, any solutions?
In your shuffling of the refrigerator you may have knocked the condensate drain away from the pain near the compressor that evaporates the water back into the air inside your home. Or you may have the refrigerator leaning in a way that the water pools up near the condensate drain pipe beginning in the rear of the freezer and has frozen over and causing the water to drain over the condensate collector pan behind the rear wall of the freezer. I have more, Sea Breeze
Oct 16, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator running. freezer will not go below 40
you need to clean the bottom of frige of dust and water there ,, and if that dont work clean pipe that goes up the back of frige
Aug 10, 2009 | Refrigerators
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
WATER DISPENCER DOES NOT WORK, YOU CAN HEART THE MOTOR GOING BUT
first thing to do is to remove the lower back panel behind the frige and disconet one of the water lines that goes to the top back of the frige and push the switch to get water with the line of. do that to the 2 lines one at to give you water back there. if none of the lines gives you water back there 100% that plastic valve needs replacing.
Dec 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water pressure
If you have a water filter, the filter might be too old and plugged. If you've replaced the filter or don't have one, I would check the water supply to the frige. You might have a kinked line. Also if you used a self piercing saddle valve on your plumbing supply it may be blocked. You would need to turn the water off to the house and replace it with a saddle valve that would require you to drill a hole in the water supply line. Also most friges have a tank in the frige to keep the water cold. If the frige is too cold it could freeze the tank. The average frige temp should be 35-36 deg.
Jul 18, 2008 | Kenmore 53642 / 53644 Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
62 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
