Question about Thermos Kitchen Appliances - Others
Syed hashmi show details 10:13 PM (12 hours ago)
Syed hashmi show details 10:13 PM (12 hours ago) tiger thermos made in japan capacity 1.5 litres fell down and the glass bottle inside broke down. WILL YOU PLEASE LET ME KNOW WHERE CAN I GET IT REPLACED IN HYDERABAD? are the parts which i get replaced will be original or compatible please regards, thanks for the help, s a hashmi
MicrowaveSvc
  • 9098 Answers
SOURCE: Glass top of oven
This is something out of an Emerson MW8107WA microwave?
I knew they used glass turntable trays...
If this is not right, could you repost the correct brand and model number?
Thanks very much.
Posted on Nov 18, 2007
  • 958 Answers
SOURCE: hotpoint tumble dryer condenser
have you clean the whole dryer air duct?. try cleaning all the walls for lints and check the blower wheel. it could be filty with lint and decreases the airflow there by increasing the temperature too much to blow those limit fuses. you would not believe how much dirt and lint we collect on those ducts. check also the exhaust hose at the back, it could hinder the flow of air if its dirty. and too many turns. as much as possible, limit the turns of the hose.
Posted on Feb 13, 2008
SOURCE: action script
poda patti
Posted on Jun 02, 2008
SOURCE: Hi I need to find a replacement inner for my
probably more economical viable to get a replacement thermos flask i'm afraid.
go for one of the stainless steel ones, they are virtually indestructible i have seen them run over by tractors , flat and still keep the contents hot.
Posted on Jul 19, 2009
  • 5 Answers
SOURCE: Who has the parts for a Soleus Air MAC -12 portable A/C
I have had the sad experience trying to get help from Soleus Air on repair parts for this problem. It's the condenser coil blower wheel that has come apart (plastic piece).
Order a quality replacement blower wheel kit at: www.shop.soleusparts.com
Posted on Aug 15, 2010
Date shows AM, should be PM. How to change, nothing in manual ?
You mean time is only coming in AM. The clocks are usually 12-Hour display. So it should automatically turn to PM once you go past 12 hours. I am assuming you have the manual and you are correct it does not show separate setup for AM or PM. You simply keep increasing the hour until it passes 12:00 and it should go to 1pm. Similarly once you go past 00 hours (midnight) it will switch to AM.
Hope this helps.
Manual for reference (won't help you if you already have it)
http://www.acurite.com/media/manuals/02010_02014_02015-instructions.pdf
Apr 28, 2014 | Acu-Rite Measuring Tools & Sensors
How to change my TAKSUN TS-623A clock from a 24 hours display to AM/PM?
Press buttons in this sequence ->
M -> M -> M
shows sec blinking
-> D to reset seconds
-> S to move to min - hr - date - month - day - sec ....
-> M to finish :)
Hold S and D to change to 12 hour in clock mode.
Mar 17, 2014 | Health & Beauty
Date change
Hi.
I take it that your watch changes date at 12 noon, instead of 12 midnight.
If so change the time of your watch 12 hours, so it reads the same time, but instead of am, it is pm, or visa versa. Analog watches do not have a 24 hour time setting.
Jan 30, 2014 | Tissot Watches
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
The link on FixYa to the HB65R Intermatic timer Manual seems to be broken. Do you still have it?
Fixya does not have HB65 manual posted.
Open following link to identify timer and download manual in English.
If this is not your timer, add a comment with clear description of timer, or in-focus photo of timer posted on flicker, so I can locate possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Jul 19, 2011 | Garden
I want to change the time from military to regular, but my bose does not have clock set just and arrow to the right and left for time
The manual is available at Bose.com and page 17-18 shows the detail.
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
May 02, 2011 | Bose Wave Radio
I need instructions on how to program my intermatic timer 1076311. It's a two button timer.
The Intermatic outdoor timer 1076311 is Intermatic model HB65R.
It has two buttons, TIME and MODE and a digital display.
Instructions:
1. Plug in the timer, which self-tests. If error, EE flashes.
If normal, 88 flashes for 3 seconds, then display shows C and you can proceed to set the timer.
2. Push the TIME button to set C (current time) AM hours 1-12 and PM hours 1. to 12. (Example: for 7 AM push the TIME button until the display shows "7" for 7 PM push the TIME button until the display shows "7."
3. Now push and hold down the MODE button until the display shows P for the "ON time."
4. Push the TIME button to set the hour to turn ON, from AM 1 to 12 or PM 1. to 12.(Example: if you want the power on at 7 PM repeatedly push the TIME button till the display reads 7.)
5. Push and hold down the MODE button until the display reads E for "END time" (time you want the power OFF)
6. Push the TIME button repeatedly to set the end time hour from AM 1 to 12 or PM 1. to 12. The time off will display.
7. Press the MODE button to toggle between ON and the current time.
If you unplug the timer you will have to reset the C (current time), P (ON time) and E (END or OFF time).
Dec 20, 2010 | Solar Intermatic Timer 6 Outlet Outdoor
I have casio Edifice E-546. The date changes at 12pm instead of 12am everyday. Can someone help/
mcdevito75 here, Many Casio Watch Models out there, I'll bet however your Casio is displaying say 1 AM rather than 1 PM as it should if the time is indeed PM after 12 noon, if so, this is why the date is changeing at 12 PM rather than, 12 AM simply re-set your casio and make sure the time of day is set at PM for time after 12 noon and AM for time anywhere before 12 NOON. Also, as you set your Casio, look for anything that may give the hint of Military time, this may be revilled as 12 hours or 24 hours, if you have anything like this, make sure it's set for 24 hours. If you have additional problems, visit a small watch repair shop in your area. Again there are many, many Casio models out there and without your watch with me it's difficult to be more accurate.
Jul 25, 2010 | Casio Edifice EFA110D-1AV Wrist Watch
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
Dec 05, 2008 | Hardware & Accessories
Kitchen Appliances - Others Logo
123 people viewed this question
Top Thermos Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Thermos Kitchen Appliances - Other Expert? Answer questions, earn points and help others
