Question about Aiptek IS-DV2 Camcorder
Camcorders Does a camcorder come with a charger?
  • MoMo Mo Jun 16, 2008
    Does It?
    Novelist:
    Champion:
  • 216 Answers
Greetings MoMo Mo,
This camcorder does not come with a charger. It can be energized in two different ways.
1) Power this camcoreder by plugging into your computer with the included USB cable.
2) Use two AA batteries (sold seperately).
I hope this helps.
Dorothy
Go Ahead. Use Us.
Posted on Jun 16, 2008
JoeO700
  • 80 Answers
SOURCE: Draining battery
This camera has had problems with the primary switch block faulting. The camera will power up all by itself when unattended and drain the battery. Another symptom would be the battery refuses to charge fully because the camera must remain in the "OFF" mode for the charge process to begin. Sony in Laredo, TX is replacing these controls at little or no cost, I would call them to see if they will repair this for you. Hope this helps you. Joe Weibel Custom Electronics (customelectronics.org)
Posted on Feb 15, 2007
  • 814 Answers
SOURCE: Hello
You can call this telephone number for the Panasonic parts sales 1-800-332-5368. Tell them the brand name and model number of the palmcorder. Ask them if they sell the connecting cable for the a/c line connector (Part numbers PV-A19 & PV-A20) to the palmcorder. You may have to purchase the complete a/c package. If so you can put the brand name and model number of the palmcorder and the above part numbers into your search engine and find alternative places to buy the a/c connector. I hope this information helps you with your problem.
Posted on Jun 10, 2009
mastertech48
  • 149 Answers
SOURCE: lost the charger of my sony dvd201 cam corder. is
Hello. Yes, you do need power to open the disc door. When you slide the disc cover open switch, you should hear the little musical sound, and then the "preparing to open cover" appears in the lcd display. Then the door opens automatically. As for charging the corder, you can get a new ac charger for 25 bucks on Ebay. Sony uses a special plug that is inserted. If you want to go the cheaper route, I saw mobile *battery* chargers for your unit(not to be used as camcorder power supplies) as inexpensive as 8 bucks...most were 10 dollars and up...the input voltage/current to the cam is 12v @ 500ma. However, the fact that the connector isn't the generic "cylinder" shaped power connector makes purchasing a compatable power source a necessity. ---Rick
Posted on Sep 16, 2009
Testimonial: "thanks very much mastertech48 ur pesponse was very helpful"
tbreeze47
  • 3083 Answers
SOURCE: zr85 camcorder will not turn no lights no power
Ok, let's try the "easy fixes" first. When this problem happens, it can be a oxidized power switch contact, or oxidized battery contacts on the camera. Clean the battery contacts and the contacts on the camcorder with an eraser gently (they are gold plated). See if the camcorder works now. The next step is only if you're not planning on taking the camcorder apart. There are times when you can give the camcorder a slightly hard "whack" with the palm of your hand, somewhere near the power switch, while the power switch is on, and if the camera works, then you know it's most likely a dirty or oxidized contact inside. See if you can get it working with these methods. If you can't, you will have to disassemble the camcorder or have it serviced. Get an estimate if you get it serviced, since it can be expensive, and you might just opt for a replacement.
Posted on Apr 24, 2010
SOURCE: I have a new jvc gr-d820ek camcorder and the mains
I have a jvc mini dv (model number GR-D820EK) and was not given a cd or a usb cable with it. I carnt transfer my footage over to my pc. Please HELP!!!! were could I buy the correct usb?????
Posted on Jul 12, 2010
I lost my charger for my digital camcorder
If you really can't find the one for your Camcorder, go and look for a Universal charger that comes with all sorts of plugs which one will fit your camcorder. When you get this Universal charger check the voltage on it. Usually the universal charger comes with many settings. Buy one with the settings that correspond to your camcorder. But one word of advice though, you must be careful when you use this kind of charger. Suppose your camera needs 8Volts for power (this is written on the label at the bottom of your camera) you be cautious then use the next lower level if it is say 6Volts. If your Camera powers on with this then keep it that way. the reason for my saying this is that sometimes the Universal Caharger is unreliable so you might get too much voltage from what is written on the Charger. Good Luck.
Oct 16, 2011 | Mustek DV526L Camcorder
How can i charge my Vivitar 550 camcorder without original charger? (Currently in remote part of Afghanistan)
Look for a ,,Universal Battery Charger" like those ,,made in China" remove your battery pack from camcorder, and insert them in the charger. The charger is inexpensive and very useful, having two adjustable flexible contacts that fits to every possible battery used in cellphones, cameras and camcorders.In my country Romania, this universal charger cost about 5 dollars or 4 Euros.
Sep 09, 2010 | Vivitar DVR-550 DV Camcorder
How do I charge the battery for a DCR-SR42 camcorder as there does not appear to be a wall-socket cable provided.
Some camcorders have only an external battery charger. You may need to purchase an aftermarket charger for your camera or a dedicated charger from your local Sony dealer.
Aug 05, 2010 | Sony Handycam DCR-SR42 Camcorder
No power from batteries and the camcorder will
I have the same problem. The battery is charged, but the camcorder will only work while plugged in. It worked for a while on the 1st day, Christmas, then it would only turn on while plugged into the charger and would stay on after charger was disconnected. Today it will only stay on if plugged into charger.
Dec 26, 2009 | JVC GZ-MG330 HDD Camcorder
I have a Sny dcr-hc48 camcorder which stopped working some time back. this week i had my friend who came with the same camcorder and i swapped in his battery and my camcorder started working. but if i...
First: put your battery in your friends camcorder and use ur friends charger to charge the battery.
Then put your battery back into your camcorder to see if it works.
If the battery works then this eliminates the battery as a problem.
Next plug your charger into your friends camcorder to see if it will power the camcorder without battery, if this works then the problem will most likley be the connector in your camcorder.
If this does not work then the problem will be the plug or the charger.
Next plug your friends charger into your camcorder if it does not work this will verify that the problem is the connector on your camcorder
binary6
Sep 16, 2009 | Sony Video Cameras
I plug in my charger and the camera shuts down, including the time. I unplug the charger and the time returns. I cannot charge the battery or run the camera with the charger plugged in. The camera and...
Disconnect the charger from the Camcorder and remove the battery.
Next, clean the metal contact of the battery and the battery compartment.
Then, insert the Battery in the Camcorder and turn it ON then press and hold the power button for 30 seconds.
After resetting the Camcorder to the default settings, connect the AC adaptor to check its operation.
If the issue persists then the DC in jack requires to be serviced.
Sep 15, 2009 | Sony Handycam CCD-TRV108 Camcorder
This camcorder was gifted to me recently and comes with an inbuilt battery. however i dont knw much about camcorders. i dont have a charger for this and dont know where is the socket for charging on the...
Yes it is the dc socket that you will use to charge your battery . It charges right on the camcorder itself with your ac adaptor . make sure the camcorder is in off postion for it to charge.
Larry
Jul 10, 2009 | JVC Everio 25x/20GB Hard Disk Drive...
Disk finalization error
dont know if youve found a solution already, but:
you cant finalzie the disc using battery power, you need to use the ac adaptor. This is something you should have got with the camcorder. its basically the charger plus another cable. so, plug in the charger to the mains as normal. then remove the battery from the camcorder, you'll notice a round hole in the camorder, this is where you plug in the cable i mentioned earlier, the other end of the cable goes into the same size hole found on the battery charger. that's it - you now have power to the camcorder from the mains. switch on the camcorder as normal and finalize the disk.
Jan 13, 2008 | Panasonic VDR-D100 DVD Camcorder
Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
Apr 13, 2006 | Samsung VP-W75 Camcorder
Aiptek IS-DV2 Camcorder Logo
44 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
prouddad_1
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
