Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
While using my 3 gallon air compressor, i noticed the sound of the compressor changed a little bit. I then noticed that the tank was not being filled with air anymore. The compressor runs fine but never produces any air in the tank. Thanks for your assistance.
Worn out piston ring How can this be oil less compressor motor
Posted on Nov 08, 2010
Blows fuses, will not run. not used much, 2 years old
Wild guess rust Does it have a tank? does it have a condensate drain? Are you sure the starting condenser is ok? It sounds almost as if the piston is frozen. Sometimes this kind of thing happens to Airconditioning compressors. You might try a "slow blow fuse" and increase fuse capacity. There is a "hard start" kit which is an extra starting electrical condenser so if none of the above helps and no warranty and mine I'd spray a tiny bit of wd-40 into the intake let it sit overnight. try again.
Mar 05, 2015 | central pneumatic 1/3 HP, 3 Gallon, 100...
6.5hp 80 gallon tank when it gets hot it shouts off
need a little more info. Does it shut off because it tripped the breaker? overload? does it boug down and stop? does it stop when trying to restart? is the compressor get hot enough to change the color of the discharge tube?
Dec 17, 2011 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Husky Pro 26 gallon air compressor ~ how do I drain water from this? I can feel a bolt on the bottom of the compressor with a rubber thing in the center. Do I need to loosen the bolt to drain it?
yes, loosen that bolt after you have built up a little bit of air in the tank, it will blow the water out , when the water quits coming out, tighten it up and your problem is over.
Jul 03, 2011 | Briggs & Stratton Air Tools & Compressors
Hi, happy new year! I just purchased the 8 gallon unit from Canadian Tire. I like it , its pretty loud. I let it break in for the required 30 min. Question, Is it common for these compressors to lose a...
When you first brake it in yes as long as its not coming out of a gasket or oil seal. But a little out the tank drain is normal and it should after 3 or 4 uses you should drain the air from the tank each use because it will build up water inside and rust the tank out if you don't.
Jan 02, 2011 | Campbell Hausfeld HL410199 Factory...
Need air tank 26 gal tank rusted through
Contact local repair shops for used tank. May be different size or configeration but a little creativity will save lots of money. Usually motor or pump will fail so there are many good tanks around. Or order new from www.chpower.com or www.toolpartsdirect.com ,good luck
Sep 29, 2010 | Campbell Hausfeld 26 - Gallon Air...
Motor starts sounding normal then after 2-3 seconds stops & just humms.
I suspect the check valve is stuck closed causing excess high pressure in the cylinder and too much load for the motor. The check valve is OFTEN right at the tank where the compressor output line goes into the tank.
Jun 09, 2010 | Coleman Powermate 11 Gallon Air Compressor
Craftsman air compressor wont hold more than 15lbs of air?
Change that coupling . You can try spraying a little WD-40 or similar into it, while you push it open with a screwdriver, just to see if that helps seal it better. If air leaking by there all the time, compressor that small can't keep up.
Apr 13, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
2-stage air compressor's recovery time takes twice as long
hi is your machine reaching full pressure? if so maybe your problem is with your tool?
Mar 23, 2009 | Air Tools & Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
253 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
