Question about Microwave Ovens
I have godrej microwave model no. gmg 17e 07 slgx.but it doesnot work properly .there is no softness in food after cooking in it.it takes large time in cooking .please give some tips of proper cooking in microwave.
3 Suggested Answers
  • 6 Answers
SOURCE: Plz. tell me how to
they are available on line, just look up the manufacturer and enter the model # and seriel #
Posted on Nov 20, 2010
  • 8909 Answers
SOURCE: Have purchased GMG 17E 07
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Jan 12, 2011
Just had an Adora DVM7195 installed. Every time I try to cook anything, the control panel says "Insert Food". In other words, I cannot get it to cook anything.
try working the directions backwards start command then open door put mug in then use select then time then start
Jan 07, 2015 | In Microwave Ovens
Godrej gmg 22a
usually check door swith doing those problem but be very carrefull to put the right one the schematic is on the side and they cost about $2.00 each you got about 3 or 4 of those but check schematic
Mar 25, 2014 | Microwave Ovens
I need user manual for Godrej 20E 08 SLGX microwave oven
I have a godraj 20E 08 SLGX MICROVIEW OVEN .Can you plz tell me can I bake in this if yes then how i preheat it for baking
Jan 23, 2013 | Kenmore Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Have purchased GMG 17E 07 SLGX Godrej Microwave &Grill, Did not recieve USER MANUAL. Please provide the same to enable to use the product Shweta
I hope this helps.
Jan 12, 2011 | Microwave Ovens
Plz. tell me how to operate Godrej GMG 17E 07 SLGX ???? Send me its user guide....
Nov 20, 2010 | Microwave Ovens
Error message SE
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect .
I hope this will help you .
please rate !
Mar 29, 2010 | Frigidaire Microwave Ovens
GE Spacemaker microwave oven - Sensor error
Hello :
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
Microwave Ovens Logo
78 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
