Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Clear pic. but black line accross television at bottom of television
  • 4,234 Answers
The first thing to check for is closed captioning. Some forms of this will result in a black text box at teh bottom of the screen. There should be an option for different versions of closed captioning on a menu. Disable it and update this if the problem remains.
Thanks,
Dan
Posted on Nov 08, 2010
Solid 2 inch black line from top to bottom
Your tv has a vert. circuit that controls your pic from top to bottom.It also has a circuit that controls the pic from side to side.Your horiz.(side to side) has collapsed.
Sep 25, 2010 | Panasonic TH-50PX75U Plasma HDTV
40wh08b convergence problem
Convergence IC's need replacement = STK392-110 original #...
Use name brand Toshiba, NAP, or upgrade to STK394-160E
Hitachi part # CZ 01341...no cheap generics..they won't hold up..
Chassis pull and some precision soldering will be needed....let me know if you need further info...........................T.
Dec 27, 2007 | Toshiba 40H80 40" Rear Projection...
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
Two Black (thick) lines that break up the screen
Play with a DVD player and see if the problem resists. If yes, may be the Y-board that control video got defective. Another posibility is the logic board. Need technician to figure out.
Aug 12, 2009 | Televison & Video
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
I have a black line accross my LCD t.v. screen
if it is a thin black line then it is probably a line of pixels out. if this is the case, the whole screen will have to be replaced and that can get pricey. i would suggest that you get it checked out by a tv tech and get an estimate, but it'll probably be cheaper to just get a new one
Oct 21, 2008 | Televison & Video
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
