Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
A single, thin, vertical line has appeared in the left portion of the picture, but not near the edge. The line runs top to bottom, usually dashed in red, blue or white, and is there all the time. Otherwise the picture is very good. The TV is about 3 years old. How can I fix this?
    Problem Solver:
  • 11 Answers
I tapped on the screen and it went away
Posted on Mar 05, 2011
I had the same problem and the dealer I purchased it from replaced it as it was still under warranty.
Posted on Nov 09, 2010
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
What could possibly be the cause of a single, yellow, pencil thin line extending vertically top to bottom of my screen about 12 from the left edge? Everything else on the TV works fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 10, 2015 | Toshiba Televison & Video
How to remove door mirror cover from 2009 ford focus
There are 7 tabs holding the mirror cover on three along the bottom ,two just below the horizontal middle line and two at the top.Squeezing the bottom corner near the car towards the outside of the mirror and pulling gently forward will release the weakest clip at the bottom.The other two bottom ones poke vertically down, the middle two hook over their slot with the hook facing down.Lifting the bottom edge of the mirror cover will help release these. As in the manual push the mirror back along the bottom edge to get some access at the top then using a thin screwdriver push down on two black clips at the left and right upper side edges of the top of the mirror try at the same time to lift the mirror cover up and towards the back of the car to release the remaining bottom and middle clips.Have a look at night with a torch and you may be able to see what is going on with the top two clips. Be careful not to apply too much pressure and break the clips.
I have taken pictures which I will try to post on another site.
Most mechanics were useless in explaining how to do this but I finally found one who could.
The other answers above are not relevant.
Jun 10, 2012 | Ford Focus Cars & Trucks
I have a thin vertical line about 9"from left side runs top to b
either a bad buffer pcb or display panel, 12 month warranty call panasonic quick
Aug 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Lines on Sony Plasma HDTV
it can be fixed but in this case i doubt its worth fixing. these problems can be astronomically expensive and personally i would buy a nice new bravia or something similar. please rate
May 11, 2009 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Laserjet 5p leaves a thin white vertical line when printing
Either the drum and/or developer is scratched or has a line on it ..
Dec 26, 2008 | HP LaserJet 5p Printer
A bright thin white line, side to side.
You need to replace the vertical IC and all the dry capacitors near to him.Good luck
Jul 06, 2008 | Sylvania 202SL8 TV
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Canon A520 Vertical line appear on images
This appears to be a failing component possibly the CCD. It may be possible to replace the camera if this is the case An offer to repair however will be almost the price of buying the next camera. Contact the Canon support website.
Sep 30, 2007 | Canon PowerShot A520 Digital Camera
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
638 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
