Question about Minolta magicolor 7300 Laser Printer
Magenta colour leaving lines on pages.
The colour magenta is leaving lines on pages. Though it is not every page. Sometimes I can print 20-30 and nothing, than the next couple of pages will hav the lines.
Can you advise
  • Minolta Master
  • 6,168 Answers
Replace the magenta image unit
Posted on Dec 26, 2015
Inky
  • 691 Answers
SOURCE: White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
Posted on Jun 11, 2007
Inky
  • 691 Answers
SOURCE: Magicolour 2350
Try updating the drivers for the printer from the manufacturers web site. I doubt the issue is related to the printer itself, otherwise it would fail to print magenta all the time.
Posted on Aug 11, 2007
  • 5 Answers
SOURCE: Magicolor 2400w Bad print quality and white lines
The solution for the white line problem in the 2400W is to clean the laser lens.
Take out the drum and wipe the laser lens with a soft clean cloth.
Replace drum and carry on.
I had to do it twice before I removed the speck of dirt that was causing this.
Wendy
Posted on May 04, 2008
ginko
  • 19396 Answers
SOURCE: We have replaced the magenta
Ensure you removed the cellotape from the cartridge. pull out and put back cartridge.
Posted on Jul 29, 2008
voodoomox
  • 1689 Answers
dave,, please do make sure that the protective tape of the cartridge is completely removed then try printing color pictures to somehow warm up the cartridge, if it still does not display anything, or print any color close to magenta, better take it back to the reseller to have it checked, tested and replaced if needed.
My Espon R230 printer has problem with Light Magenta colour, i bought new cartridge but then also light magenta nozzle check is not clear, i think it is printer problem, please help me how to solve it
First you could do a printer test. The printer will print a small pattern with all colours making it possible to check if and if so, what nozzle are blocked. Sometimes the cleaning cycle will help, but sometimes there is just some dirt under the head. Please don't try to remove it with tools if there is something. Just use a thick piece or printing paper to solve that problem. Please check the manual for details. Perhaps the epson site can help you with that:
http://www.epson.com.sg/sites/epson_singapore/support/support.page
Jan 12, 2015 | Epson STYLUS R230 InkJet Photo Printer
Panasonic leaves pink lines on my printing
Your Panasonic dp-c requires a new magenta coloured drum.
Mel Page
Jul 23, 2014 | Panasonic WORKiO DP-C262 Printer
Prints with magenta wide lines
Your magenta imaging unit life finish,need must be change the imaging unit.
Feb 28, 2013 | Canon LBP5960 A3 Colour Laser & Free Toner...
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
I have a Gestetner DSc38u and when I print colour I get a 'red'/'pink' line about an inch from the top of each page. Any suggestions?
If the line is only red or pink, it is most likely caused by the magenta PCU. Replace this PCU and your problem will go away.
Occasionally the magenta developer unit can cause a red or pink line, but the problem is more than likely from your magenta PCU. The PCU is easy to replace, and instructions will come in the box if you order an OEM replacement unit.
Jan 22, 2011 | Ricoh Aficio 3800CMF Laser Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
Jan 13, 2010 | OKI C9500dxn Led Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Minolta magicolor 7300 Laser Printer Logo
64 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
