Question about Whirlpool GX5FHTXTS Stainless Steel Bottom Freezer French Door Refrigerator
Whirlpool stainless french door refrig...need to take handle off bottom freezer door so I can move it out of house. Is this possible without taking off the whole door?
    President:
  • 1,891 Answers
It is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
Posted on Nov 08, 2010
WHIRL POOL STAINLESS STEEL FRENCH DOOR- BOTTOM FREEZER MODEL NUMBER GI5FSAXVY
You should be able to buy replacement stripping at any local hardware and furniture store.
Sep 16, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
I have a maytag refrig that I can not figure out how to reprogram the freezer temp and refrig temp.
https://www.maytag.com/digitalassets/MLPDF/User%20Instructions%20-%20W10175444A.pdf
Page 9 how to set controls
Jul 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
How do I initiate defrost in a Maytag tri-door
Try this open the freezer door and flick the light switch 6 times, like flick, ----- flick,----- flick. If 6 does not work try 8, cant remember.
Aug 22, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Feb 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool GX5FHTXTS Stainless Steel Bottom Freezer French Door Refrigerator Logo
230 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
