Question about Bertazzoni Pro Series X304GGV Kitchen Range
Oven fan won't turn off after I shut it off. what do I do?
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
Fan won't shut off after oven cools down
Most fan ovens have a control sensor which allows tthe fan to operate even after you have turned the oven off to prevent overheating.
It sounds as if this sensor has stuck in the closed position thus leaving the fan running .
You will need to replace the fan control unit at the back of the oven.
Dec 31, 2009 | Whirlpool RBD305PD Electric Double Oven
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
May 31, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Control panel fan won't turn off
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
Jan 26, 2008 | Dacor Epicure 30" Double Wall Oven,...
Bertazzoni Pro Series X304GGV Kitchen Range Logo
234 people viewed this question
Top Bertazzoni Kitchen Ranges Experts
ray gallant
Anthony Kelly
Anthony Kelly
S Sigs
S Sigs
Are you a Bertazzoni Kitchen Range Expert? Answer questions, earn points and help others
