Question about Solis Palazzo Espresso Machine
I accidently poured about half a cup of water into the bean hopper. Now it still grinds beans but it will not start to cycle (the bean light does not turn off). Can i take it apart and dry it out or clean it out.
  • 1,089 Answers
Taking the grinder apart is not easy to do and get it back the way it is suppose to be is not easy. The first thing I would do is turn the big knob to the 18 or max and the small knob to the -, and try again. If that works leave it there for a couple shots to clean everything out. If that works continue. Then while the grinder is grinding, turn the big knob back down to 8-10 and make some more drinks. 6 to 8 is a good start.
If it didn't work you will need directions but the damage may be already done. The burrs ghave no coating on them and they can rust very quickly. you may need new burrs or a new grinder.
I have a saying " If you are working on the water, keep the bean hopper covered and vice versa". Cross contamination will damage the machine very quickly.
Posted on Nov 08, 2010
  • 2 more comments
  • jhuser Nov 09, 2010
    Thanks , I did as you said, but first i vacumed the grinder and the hatch behind the main group assembly, a lot of grounds came out . Then i turned the knobs to 18 and -,then put new beans in the hopper and tried to make coffee..............The grinder grinds the beans for about 10 seconds as normal ,but the bean light stays on and the machine wont go to the next step in the cycle.
    Do you think I short circuited something when I poured the water into the hopper?
    Whats my next step , send it out for service? , I hate to send it away if I might be able to repair it .
    Thanks for your time.
  • bansheracer Nov 12, 2010
    The problem witgh water in the grinder it can get into the sun gears below the grinder. If the grinder turns its not shorted. There is a long passage from the grinder to the doser and that can get gummed with wet coffee, that dries hard. It might be better to get a new grinder. I have some.
  • jhuser Nov 12, 2010
    Thanks my friend that is good information .........I realized that it was probably beyond my skills to get it going..........so i sent it away to get repaired. Thank for your time.
Bean hopper is full, machine starts to grind the coffee but right before it starts to pull the shot, it stops & says "add beans to hopper".
the add beans to hopper signal most likely is triggered by the machine not sensing enough load put on the grinder (hence it thinks its out of beans) , this most likely is set by the grind (fine/course ) id say the grind is set to an improper size and the automatic sensor is picking up on that
another thing is the coffee / if its way too moist and not dry enough then its also going to trip the sensor as well
Feb 26, 2016 | Coffee Makers & Espresso Machines
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Cleaning burrs of oily residue
Hi
There are many ways to clean oily residue from your burrs. You can order a grinder cleaning tablet from online stores called Grinds by Urnex. Some people use white rice but if you don't get it all out you will have rice in your coffee. You can take them apart and clean them manually but if you don't reassemble it correctly you will not get a good grind. I think the easiest way is to get some cheap light roasted beans ( doesn't matter if they are old ) but never use shiny beans because shiny beans have lots of oil.
Set the grinder to a very coarse setting, on a Rocky 7 higher that you currently use. You can turn it to a larger # any time but it has to be grinding to turn it to a lower #. Pour a cup of cleaner (beans, or rice) into the bean hopper and turn the grinder on. Grind the whole hopper through the machine. If you use grinds just a couple of #'s higher is all you need. Once you have cleaned the burrs you will need to grind some of you beans to purg the cleaning debris for the burrs and chamber. When you see no more cleaning compound you can turn the hopper back to where it was leaving the motor run. Once you get it back test with your beans.
May 12, 2011 | Rancilio (RAROCKYND) Grinder
My cuisinart cbm-18 does not grind at below a 10 setting?
Hello, and thanks for using FixYa.
I'm guessing the problem is that the grinders blades, or the parts that do the grinding have become somewhat dull, (opposite from Sharp.) and no longer can get to the beans like it used to.
Cleaning the machine properly might improve its performance.
CLEANING/MAINTENANCE INSTRUCTIONS
1. Be sure plug has been removed from outlet.
2. Beans can be removed from the hopper by lifting off the lid and pouring excess beans out. Hold down the Manual button to cleanout any remaining beans.
3. The bean hopper, bean hopper lid, grind chamber, and grind chamber lid can be washed by hand with hot, soapy water or placed in the top shelf of a dishwasher. Dry thoroughly.
a. Remove the bean hopper by rotating counter-clockwise bringing the selector past grind setting 18, align the arrows and lift up. Make sure the hopper is empty.
b. Remove grind chamber by pulling toward you.
4. Remove the burr grinder, once the bean hopper has been removed, by grasping the metal handle and lifting up. Use the brush to remove grinds or wash by hand. Replace the burr grinder onto the unit and rotate until the piece is fully inserted. Push handle down and replace hopper.
NOTE: The hopper will not attach to the unit if the grinder has not been fully inserted.
5. Wipe body of grinder with a damp cloth.
6. Any other servicing or maintenance should be performed by an authorized service representative.
WARNING: NEvER ImmERSE UNIT IN WATER
Oct 14, 2010 | Cuisinart CBM18 Electric Grinder
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Solis Palazzo Espresso Machine Logo
151 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
