Question about Sony VAIO VGN-FJ270/B Notebook
Wide Screen My vaio has a wide, rectangular screen and recently it has only been displaying a square that does not occupy the whole screen, how do i make the picture fill the whole space again?
    Genius:
  • 1,847 Answers
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Posted on Jun 17, 2008
Display too wide on monitor
if you r using WIN 7.then on desktop right click on blank area and choose screen resolution.
now select recommended resolution from the select.
Aug 31, 2014 | ViewSonic Computers & Internet
My old analog Zennith TV is displaying in what appears to be wide screen. This happened all of a sudden. Can I fix it or is it dead.
could be a deflection problem or if picture is somewhat small top or bottom or both only a vertical problem--if very old set parts may no longer be available.
Oct 15, 2012 | Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hi, I got a VAIO PCG-K27 Notebook from my friend recently, got problem so need to load window XP os. Now after reloading and reformatting i am having view small ( less 1.5" both sides left and right)...
Use your mouse to RIGHT CLICK on an empty area of your desktop.
Select PROPERTIES.
Select SETTINGS tab.
Move the SCREEN RESOLUTION SLIDER to a different setting.
Click APPLY.
Keep trying different settings until you find one that is acceptable.
Then Click APPLY and OK and then reboot your computer.
That should do it.
Good luck and please rate this with 4 Thumbs Up if it was helpful.
Thank you.
Feb 14, 2011 | Sony VAIO 15.4" Widescreen Notebook PC...
I connected my media center PC to my new Sanyo DP50740 50" Plasma Television using the PC input on the back of the television. The instructions say that it supports 1360X768 with a 16:9 aspect ration...
No,13060 resolutions will not support by some tv correctly,will shift whole picture about to 6 inches to the right.That why,must use the PC Control panel to adjust to 1024 for the video to center.For the wide aspect 16:9 ratio,just find another aspect ratio to for expandsion to fit the entire screen.
Feb 05, 2011 | Sanyo Televison & Video
The HANNSPREE monitor that I just bought is great except for one thing. As a photographer, the HANNSPREE screen is too wide in relation to the normal photograph sizes. The horizontal linear distortion...
The best way to adjust the screen is to adjust the screen resolution until you get a correctly proportioned image.
First display an image such as a square or a circle on the screen.
Go to Control panel - Display - Settings tab and start with 1024 X 768 screen resolution adjustment
click Apply and the check your image.
Repeat the adjust screen resolution select the next highest screen resolution setting, repeat thia process until you get the best image.
Jan 24, 2011 | Computers & Internet
How to get an undistorted picture without cropping. This is an Olevia, and it is not listed below.
I assume you have a wide screen tv? most TV show are broadcast in a square (4:3) format, on a wide screen television the screen is rectangular, so to fit the square picture on the rectangle screen you have to either crop the top and bottom, or stretch and distort the image. the only real solutions are either to watch everything in the 4:3 format (leaving the sides of your screen blank), or subscribe to HD which will broadcast most programs in a wide screen format with out distortion.
Sep 14, 2010 | Televison & Video
With windows7 screen is small@1024/768 is ok if you use 1440/768 how can i use 1024/768 and get full screen 20 ' wide screen
Hello.
If you have a Wide screen monitor it can only (look good) in a Wide screen resolution such as 1440x768.
1024X768 is the lower resolution, and it is for normal screen (square) monitors, not for wide screen monitors.
You cannot get a full screen at 1024X768 resolution with a Wide Screen Monitor.
Hope that Helps.
Jan 29, 2010 | Evga N350 NVIDA 6600GT 128MB 128bit AGP8X...
No showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Feb 16, 2009 | Dell E153FP 15" LCD Monitor
Sony VAIO VGN-FJ270/B Notebook Logo
155 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
