Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Left and right sides, seeing triples in three colors,but the center is fine?
  • Mitsubishi Master
  • 8,457 Answers
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have picture colors shadows or 3D picture look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Nov 08, 2010
Screen is stuck fully expanded on startup screen
Maybe you have turned on the Zoom settings from the Accessibility menu. To zoom out, Triple tap the screen with three fingers until the screen zooms out. To disable Zoom, go to Settings > General > Accessibility, look for Zoom then click to disable.
Tips for Zoom:
- To zoom in or out, triple tap the screen.
- To adjust the magnification of the screen, press and hold with three fingers, then scroll up and down to change.
- To navigate the screen, swipe using three fingers to left, right, up or down.
Hope it helps!
Cheers!
-Josh
/uploads/images/screen-stuck-fully-expanded-startup-35310085-5-1.jpg
Mar 27, 2015 | Apple iPhone 5c
Pionreer 64" hdtv, I think
Bad Convergence ICs they are Big Black ICs and will have the part number on them STK392-110
Mats has ICs $10.95 each 1-800-628-1118 In back of TV look on Board Located on Left hand side thats where you will find the ICs.
Jul 30, 2011 | Pioneer PRO-730HD 64" Rear Projection...
My projection tv is showing a triple image and i don't know how to fix it?
Go to menu then setup if you do not see convergence listed in menu then you have blow Fuse FL231. Located next to FBT flyback transfomer on right side there is 3 fuses in a roll they will look like small rectrangler caps but are Fuses.06 amp
Apr 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rgb will not line up in hd
please check inside it might have cold solder on CRT board that can affect purity,or pole convergence.
Aug 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
Need wire diagram for the turn signal switch.
your wires are crossed/shorting somewhere, probably in the headlight. remove the light to get to all the wires. you should be able to see which colors go to which side, also look at the wires coming from the turn signals both front and rear lefts will be same color and the rights will be another color. you should be able to tell by looking inside the switch which side is which color and which one is the feed to the switch
Apr 09, 2009 | 1981 kawasaki Csr 1000
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
Three colors line up on some spots but not others
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Zenith IQB50M90W 50" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
