Question about Maytag Dryers
We have a maytag double stack commercial dryer model No MLG 15 PDAGW. The problem is the upper dryer is cutting out after 3 minutes with the diagnostic code number d19 upper dryer temperature to high.We have cleaned the vents changed the thermostats the Thermistor temp control and coils trying rectify the problem but it still cuts out after 3 minutes with the same diagnostic code number.
  • 3 more comments
  • stay599 Nov 08, 2010
    Thanks for your reply we have replaced the wheel blower and have checked that we have proper airflow everything seems to be working properly.
  • stay599 Nov 10, 2010
    Thanks Daniel for your reply we have replaced the wheel blower and have checked that we have proper airflow everything seems to be working properly.
    Thanks for your reply we have replaced the wheel blower and have checked that we have proper airflow everything seems to be working properly but it is still cutting out and showing the error code..
    Yes "difficult" we have replaced the hi limit thermo with a new one cleaned all the filters. When you put in wet items the machine works fine until it gets to near the dry end and then just turns off. We have checked the temp but it is running cooler than the bottom dryer. We think its the Board " Long Shot ". But we feel we have tried everything.
    Thanks Daniel we have checked the wireing and have changed the thermostat cycling or thermistor , temp , control still turns off. We feel we have checked and replaced every part that would cause the machine to overheat. The temp is pre set is there any way of checking that the pre set temp is still 140.
  • 4,323 Answers
Hi
Hope your dryer is working fine now. If it is not then please post back for further assistance.
Thanks Daniel
Posted on Nov 09, 2010
  • Daniel Scott
    Daniel Scott Nov 10, 2010
    Hi
    You'll also need to check the wiring, there would be shorted/open circuit. Please check the wiring diagram---
    In case the wiring is fine then you'll need to replace the cycling thermostat. Please check part#4 in the following diagram---
    Hope this helps... Please post back if you need further assistance.
    Daniel
    President:
  • 1,891 Answers
Because this is a double stack ck the air flow of the lower dryer ( remove vent hose and feel the air flow then see if top dryer is about the same .. the problem can be the blower is not moving the air so it's shutting of on hi limot control .. mm hope this helps feed back pls
Posted on Nov 08, 2010
  • 2 more comments
  • dennis dodge Nov 10, 2010
    Have you tried the dryer off the vent as if it restrcted the you will get a code . and the heat will keep shutting down . some time the simple things are missed or over looked . . ck your filter screen some times the small air holes are restricted . this is caused by fabric softners . . clean the screen with mild soap . the screen can become 60 pre cent restricted and this will slow air flow . to the max . and add dry time to cycle . but try the dryer with no clothes no filter and off the vent and see what hapens . if heat stays on the i would say the vent is problem .. mm hope this will help . feed back pls .. mm
    ps you may have a week hi limit thermo on this dryer . try to by pass it and if it works the replace it . just gussing at this point .. but ya gata keep looking .. mm
  • dennis dodge Nov 11, 2010
    when you said it cuts out / does the only the heat go out or does the dryer stop / and how do you get it to get going again. . . remove the belt and give the blower a spin when it stops and see if motor spins freely . if all has been cked you may have a bad control.
    mm do you have the model # of your unit ?
Adc dryer yes drum turns exhaust clear lots of make up air no heat
I'm assuming this is the commercial model?
first thing unplug for 5 minutes plug back in to see if it resets.
here is the parts break down if you need parts.
thermometer?
https://www.partswarehouse.com/Maytag-MLG32PDBWW-Gas-Dryer-s/105269.htm
Jan 05, 2018 | Dryers
I need color coded wiring diagram for maytag combo model # lse8500ace
Double Check Model Number. Can't find anything with that model. Have LSE1000 and LSE7806 which are stacked Washer and Dryer
Nov 18, 2015 | Maytag Dryers
Start button want stay on
this is most likely to be upper control board/located in the top of dryer
Feb 18, 2013 | Maytag Neptune Washer
Lavadora maytag mlg 2000 aww la inicio en lavar esta lllenando a los 20 segundos se apaga , la pongo a exprimir tira el agua pero a loa 20 segundos se apaga doy gracias
hola por que cuando encho ropa a la lavora y le pongo el ciclo adecuado y a los 20 min o segundos me aparece un error f20 mi lavadora es maytag frontal ke puedo hacer????????
Jan 12, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
I have a commercial gas dryer model #mdg16fdaww. when you turn it on it everything works fine, but after 15 seconds the gas and the igniter cut out but it keeps spinning. is it a sensor?
It is either the "high limit thermostat" or the "flame sensor". Check the thermostat for continuity with a multimeter to see if it is good. Here is a link to the thermostat in case you need it. Here is the link to the flame sensor in case you need that.
Dec 31, 2010 | Maytag Dryers
HiMy name is Ray and i would like to increase the drying time on a maytag commercial dyer model lde19cs
i just got off the phone with Maytag Commercial Laundry customer service, because i needed to know how to adjust the run times on this dryer model. here is what i learned:
there are slots in the timing cam into which fit a white pin for adjusting the run time. the letter settings on the cam are set at 12 minutes apart:
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
if your dryer is running 48 minutes, that pin is likely in the 'B' slot. remove the pin. the built-in stop at the 'A' position is for 60 minutes.
May 28, 2009 | Maytag Dryers
Need mother board for maytag dryer model ldg23cd can not find one
I have about 20 of these boards in working condition. If you need one, let me know.
Coin Operated Double Stack Dryers - LDG23CD Dryer Board 3-6236 (or possibly 3-6443 or 9-12086)
Board - This part has been discontinued by the manufacturer and is no longer available.
Touch Pad AP4037678
Part Number: AP276590
Manufacturer's Number: 306236 (3-6236)
May 27, 2009 | Maytag MDE16CS Electric Dryer
Dryers Logo
324 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
