Question about JVC KD-DV5100 CD Player
Car stereo/cd/dvd player
I can hear the dvd's play. I can also hear the cd's. But i cannot see a picture on my screen. It just says "NO SIGNAL"
  • 1,586 Answers
Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done. If you can't get it to work with this process (or whichever process the manufacturer describes in the manual), then that wire may not have been hooked up, or could have been hooked up incorrectly. You'll probably have to remove the head unit to investigate this.
Posted on Jul 23, 2008
IVA-D106 Car DVD Player: no picture on screen while dvd is playing...
Im guessing that if you can hear sound but have no picture and this is newly installed that your unit is wired to your parking brake as a safety feature. You need to disconnect it and connect the wire to the radio ground to bypass it.
May 18, 2010 | Alpine IVA-D106 Car DVD Player
Car dvd player cannot play disk
See if unit has a reset to factory defaults. Also check with Kenwood. If not results are achieved unit needs replacement
Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Sep 21, 2017 | Kenwood Car Audio & Video
Overhead DVD monitor screen dead but sound plays through stereo
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
Hope this helps....
Apr 08, 2009 | Rosen A7 Car DVD Player
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
I have a Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player i can play music on it ,wen i insert a dvd the screen goes black i can hear the dvd playing on my speakers but no picture comes...
there is a safety brake wire that needs to be hooked up. If it was installed professionally, have them explain it to you.There is not supposed to be any video players in view of the driver while in motion. Stop your car and put on the parking brake. If you installed it yourself, you probably didnt hook up the wire. Look inthe install manual for DVD safety wire.
Dec 21, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Can't hear right speakers your player have a stereo option for the DVD..can you make sure that's selected?
Mar 17, 2008 | Jensen VM9020TS Car DVD Player
Car dvd player with cd changer
Can you provide more information? What kind of vehicle is this in? Do you hear audio when the Tuner is selected, or when you're playing a CD?
Jun 10, 2007 | Alpine IVA-D901 Car DVD Player
No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
May 06, 2007 | Blaupunkt DVD-ME2 Car DVD Player
It sounds like the video signal is being routed to a different out put. Search the menu for "Source" kinds of settings. Often you will have Vid 1 and 2 and maybe HDMI 1 &2 etc. Try what looks right and keep trying all combinations (usually less than 6). Take your time, it often takes them numerous seconds to recognize the signal. The fact you see the settings means the Video is working if it just had the signal. Also, if there is any wiring involved, check the cables and maybe swap them for known good ones if possible.
May 20, 2017 | Pyle PLDINTV7 Car DVD Player
JVC KD-DV5100 CD Player Logo
150 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
