Question about Insignia Kix MP3 Player
Will Not Start Up
Push Button To Turn On & Green insignia comes on & After 8 to 12 seconds it closes down
    Sergeant:
  • 250 Answers
Hello 123cat,
The rechardeable battery in the Insignia Kix MP3 player has a finite lifespan. The amount of operating time you can expect in between charges will naturally decrease until the battery gets to a point where it is no longer able to power the unit. Assuming you are charging the unit properly, it sounds like you may have reached that point.
You can purchase a new rechargeable battery for this unit by going to
http://bestbuy.partsearch.com
Best Regards!
Ken
"Go Ahead. Use Us."
Posted on Jun 17, 2008
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
Printer does not print
Instructions
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    Ge adora washing machine beeps when pushing start with door closed
    Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
    Dec 07, 2012 | GE WSXH208A Front Load Washer
    When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
    Please reset the Printer by following these steps:
    Feb 27, 2011 | Canon MX310 Office All-In-One Printer
    Insignia LCD TV 32 inch will not come on
    I received no replies to my request. I guest I stumped 2 million techs. I'll just buy a new TV with a 5 yr warranty. No thanks to joining your service, I can do bad all by myself.
    Feb 08, 2010 | Insignia IS-LCDTV32 32 in. Television
    Where?
    power button is the little nipple between the phone and play/pause pictures on right side. You hold down for 2 seconds until blue light comes on to turn on.
    Too shut off hold down button 4 until red light comes on.
    if want too pair with device hold button down 6 seconds until light blinks blue red
    pass code is 0000
    May 15, 2009 | Insignia Bluetooth Wireless Headphones...
    Insignia TV
    Ok, I had the exact same problem last summer, and Kevellen told me of a problem that Insignia tv's have: the circuit that controls whether the tv is off or on is messed up, and it can be fixed, but its not cheap.
    http://www.fixya.com/support/t924975-wierdness_tv
    Anyway, if the t.v. is still under warranty, I would say return it to the store and see if you cant get a new one, and from what I researched online after this incident, I will not buy an Insignia aver again.
    hope this helps,
    -Steve
    Aug 17, 2008 | Insignia NS- 27" TV27 TV
    Turning on
    I second quavuama. I had the same symptoms after my four-year-old "broke" it. He actually figured it out and suggested the fix. He said "Daddy, the little button is stuck..." OK, yeah right, I said. But he pointed to the small auto shut-off button just above the source and setup buttons. When the lid closes the button is pushed down and off goes the picture. Well little four-year-old fingers was fingering the button and it got stuck in the down position. I used a sharp tip to work it back to the "sprung" position. Picture now comes on.
    Mar 13, 2008 | Insignia NS-PDVD8 Portable DVD Player
    Open Questions:
    Insignia Kix MP3 Player Logo
    160 people viewed this question
    Top Insignia Audio Players & Recorders Experts
    Alan Matzke
    Alan Matzke
    jason
    Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
