Alert on what? Are you referring to a radar detector, navigation system, or something else? Have you checked the manufactuer's website of whatever device to see if there are updates? Often updates are slow to get distributed when it comes to navigation systems.
I know this sounds silly but check and see if you set it to mute. Most detectors have this option either in the set up sequence or by pushing the volume button down.
but see if you accidentally set it to mute. Most detectors allow a mute setting and only light flash. This can b
I should have mentioned if none of the suggestions work you may have a burned out speaker. The heat generated by the windshield dries the speakers out. I have had two speakers replaced in my Whistler 78 Pro in the last 5 or 6 years.
go into your setting and check that you have not set it so sound for things like going over the speed limit or places of safety. it should be in your safety alert settings or something like that
recent worldwide changes in radar technology means that detector technology is not always capable at detecting these mobile cameras, The only way to keep up to date with the newer technology is to constantly keep updating your radar detector. The only issue is they only have to make small changes to the cameras and the new technology won't work.
remove the processor heatsink and the processor clean the surface and apply a thin layer of heat sink compound and fix back the processor and also check the processor fan is working if the processor is fauly the processor heats up quickly and shutdown the computer
The CHEAPEST & EASIEST solution to your problem is going to walmart and buying a GPS. This happened to me I was going to spend more money on getting it fixed and I was to afraid to go in and fix it myself for fear of messing anything else up. The GPS will tell you the current speed you're going aswell as the posted speed limit. it will alert you when you are speeding also.
This is because the Sunkyong Early Warning radar detector is an absolute piece of junk in terms of actual radar detection performance. It performance is dismal compared to any product manufactured by Bel, Escort, Whistler's higher end products, or Valentine Research. Let me guess -- you bought your Early Warning RD off of eBay.
