Back to:
Tags:
Umax Astra 1220P Flatbed Scanner
INSTALL AN UMAX ASTRA 1220P TO AN USB PORT ON A... (by 2 users)
posted by Lactankey on Jun 16, 2008
I try to install the driver of an UMAX 1220p (parallel port) to an USB port of a laptop, but I can't make it.
Can some one help me out on this issue. The problem here is the driver and the port, and the scanner is the one designed to work with a parallel port.
I bought an USB to parallel cable and connect the scanner to the USB port of my new laptop that does not have parallel port any more.
Lactan N.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by nvh113, posted on Oct 08, 2008
INSTALL AN UMAX ASTRA 1220P TO AN USB PORT ON A LAPTOP USING XP
Can you Help with these Scanners problems?
Scanners
tengo un scanner alaska 5000u y baje los drivers para el...
Scanners
how do i scan documents using my hpfax1250 and send them...
Scanners
release lock & detach I/f cable.
when i use the scanner the colour of the output copy is so...
Loading problems.
Repair Service
Find Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
