Question about Electrolux Cooktops
Need to know fittings for wiring for westinghouse php284u cooktop
4yrs old, blew the house fuse and no longer works
You have a short some where in the cook top,or wire thereto, you need to replace? cost vs Appliance repair service. If it is a cooktop that fits on a counter top you may be able to remove and replace with "lightly used" Check with family or friends who are electrical and safety Literate to take a look. They may find a loose or burned wire.
Mar 12, 2015 | Cooktops
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
Westinghouse 808 cooktop clicking noises
Sometimes after a power failure the p c board needs re setting. Turn off the power for a few minutes that allows it time to re set. Turn it back on then individually turn on each element for a couple of minutes.
Apr 22, 2014 | Whirlpool Cooktops
Replacing wires on surface element switch(kenmore cooktop)..need to know where they hook up
Usually you can copy wiring from other element. Safest to consult wiring diagram found inside control panel.
Feb 18, 2014 | Kenmore Cooktops
Westinghouse gas hob four burner only one igniting the other three only light with a match gas coming through but no spark
Clean the wires going to the ignitor of each burner, clean the burners as well. Chances are you have too much oil and dirt on them that is why your burners are not igniting.
Jan 27, 2014 | Cooktops
How to modify the tile to fit the cooktop
Can you be a little more specific?
The tile usually sits on a substrate and then the substrate sits on the counter.
Does the new cooktop fit into the current cabinet or does that also need to be modified?
How much more space do you need?
How far past the new cut line will the cooktop cover?
Short answer would be a grinder with a masonry cutting blade.
...and a vacuum.
Nov 29, 2012 | Jenn-Air 30 in. CVE3401 Electric Cooktop
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
Trying to get hold of a fitting instruction leaflet plus list of spare parts for a gas hob code no. E4NE T2484SOEU/01
Why do you need a fitting manual ? Any competent gas engineer should know the contents of BS6172 / BS6891 which both apply to the fitting of domestic gas cookers / hobs. What spares do you need. You can get a spares inventory from Neff. Ensure that it is the correct appliance for the fuel gas you are connecting to. The jet sizes for LPG & Natural Gas are very different.
Apr 16, 2009 | Neff T2346 Gas Cooktop
Need to replace 46 inch electric cooktop made by dacor
I'm in the same boat & can't find anything that will fit my existing 46"wide X 20.5" height Decor electric cooktop. Would love to know if anyone else has found something.
Mar 20, 2009 | Cooktops
Wiring for a jenn air cooktop jec8536adb
Hi, I'm sure by now you probably have this fixed. Anyway, It is important that you know some information, like what the voltage is of the black and white wires coming in. The electrical codes in most places call for the 3rd wire which would be a neutral. If the old wiring has a metal conduit it is possible that it is being used as a ground and it may have been assumed that if the ground and neutral wires in the distribution panel were connected to the same bus that it wouldn't matter. Not the safest way to go but it will still work if you have no other wires. The incoming would probably be each a 110vac leg which the black would connect to black and the red from the cooktop would connect to the white of the incoming and the white of the cooktop would be sealed off. If you need additional help please let us know. Good Luck!
Jan 31, 2009 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
Top Electrolux Cooktops Experts
rugby prop
paulcarew
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
