Question about Kodak EasyShare M863 Digital Camera
My lense will not come out - Kodak EasyShare M863 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 08, 2010
Testimonial: "Thanks for your help. It is now working"
What kind of lenses should I buy for my new Pentax Kr? People tell me to buy new digital lenses. What is the real scoop on lenses for this camera?
Newer lenses tend to be sharper and lighter than older lenses, and with better optical characteristics. Some digital-only lenses are also designed for the smaller sensors of some digital cameras, allowing for further reductions in size and weight. In general, lenses designed for film cameras will work with digital cameras.
If you already have Pentax-mount lenses, by all means continuing using them if you're satisfied with the results.
Jul 20, 2012 | Ricoh Cameras
What DSLR to use with Tamron AF 28-200 and 200-400 lenses
Hi, all the Sony Alpha dslr's will work on these lenses, try to get a newer model, most of these older lenses are as good if not better than the new kit lenses that come with cameras now
Jun 20, 2012 | Tamron Cameras
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
Cant find holbrooke oakley lenses replacement... if there any way replacement lenses for tham&
Typically Oakley has replacement lenses for their glasses but because the Holbrooke is so new it is probably going to be awhile before they have parts available. The guys at www.sunglassreplacementlenses.com could probably custom make you a set of after market lenses for about half of what Oakley will want for their lenses. You may want to email them if your lenses are thrashed.
Thanks
Jun 03, 2011 | Oakley Holbrook Sunglasses
Compatible nikkor lenses for nikon f 55
Almost all Nikon-mount lenses made in the past half-century will work on the F55. With old lenses, you need to make sure they're AI or adapted to AI. Among newer lenses, you don't want to use the DX lenses designed specifically for digital cameras. DX lenses will work, but you will get vignetting (dark shadows in the corners). You will also lose the autofocusing capability with AF-S lenses.
Jan 24, 2011 | Cameras
What is so unique about Polycarbonate Lenses?
Polycarbonate lenses are the most-used alternative material for modern ophthalmic lenses. Consumer interest in thinner, more attractive spectacle lenses led to the development of special lens materials that would bend light differently than conventional plastic lenses. These materials are called "hi-index".
Among the high index materials developed for eyeglasses is one material that has a number of very unique properties and that also provides special benefits to eyeglass wearers. It carries the generic name "polycarbonate" but is sometimes called something different by other manufacturer trade names.
Great for sports protective eyewear
A "must" for kids
Comes with FREE Scratch and UV Protection
Impact Resistant - Polycarbonate Surpass AR lenses are 10 times more impact resistant than plastic lenses.
Lighter - Polycarbonate Surpass AR lenses are up to 35% lighter and thinner than standard plastic lenses for greater comfort.
UV Protection - Polycarbonate Surpass AR lenses shield your eyes from virtually 100% of the sun's harmful UV rays.
Scratch Resistant - PolyCarbonate Surpass AR lenses are hardcoated for excellent durability and scratch resistance.
Easy Care - PENTAX EasyClean™ treatment resists dust and smudges, making your Polycarbonate Surpass AR lenses easy to clean.
Polycarbonate was the first plastic high index lens and still has one of the highest index ratings (1.59). High index advantages are included with every polycarbonate lens so there is never any extra charge for high index when polycarbonate lenses are ordered. Originally used primarily for industrial safety glasses, now used for children, sports wearers, or anyone requesting greater impact resistance in their lenses.
Nov 07, 2010 | Clothing Accessories
What are the differences between lenses? I know some are made of plastic and some from glass..Thanks!
There are couple of materials in which sunglassess are made of. 1. Glass Lenses
- it's has number of advantages: -Exceptional scratch resistance (don't need scratch resistant coating).
-Excellent optical clarity.
-Anti-reflective (AR) coating adheres to glass very well.Disadvantages are:-At least twice the weight of plastic or polycarbonate lenses.
-About 25 to 40 percent thicker than polycarbonate and high index plastic lenses.
-Can shatter or chip easier than lenses made of other materials.
-Require a special coating to provide 100% UV protection Second type is Plastic Lenses:Advantages:
Lightweight - About half the weight of glass lenses.
Plastic lenses accept tints easily.
More shatter - resistant than glass lenses.
Disadvantages:
About 20 to 35 percent thicker than polycarbonate or high index plastic lenses.
Require scratch-resistant coating for added durability.
Require a special coating to provide 100% UV protection.
Another type is Polycarbonate Lenses:Advantages:
Safest lens material - 10 times more impact resistant than other lenses.
Thin - About 20 to 25 percent thinner than plastic or glass lenses.
Lightweight - About 20 percent lighter than plastic lenses.
Blocks 100 percent UV rays without needing a special coating.
Disadvantages:
Requires scratch-resistant coating for durability.
Peripheral vision may be slightly less clear in strong prescription powers.
More lens reflections than glass or plastic lenses (AR coating recommended). High Index Plastic Lenses-Advantages:
Lightweight - Between plastic and polycarbonate lenses in weight.
Thin - About 15 to 30 percent thinner than plastic lenses.
Better peripheral optics than polycarbonate lenses (for prescription sunglasses).
Disadvantages:
What canon digital camera will use my old Canon AE1 fd lenses?
You can buy an adapter to use FD mount lenses on EOS mount cameras. See this page for more details.
Jan 11, 2009 | Canon Cameras
Lense adapter and extra lenses for fuji finepix E900
There are several of what you are looking for on eBay. They are slip on to fit the E900
Jan 04, 2008 | Fuji FinePix E900 Lens Adaptor Ring Lens...
Kodak EasyShare M863 Digital Camera Logo
374 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
