Question about Sony DCR-VX2000 Mini DV Digital Camcorder
Sound cuts out and video image jitters - Sony DCR-VX2000 Mini DV Digital Camcorder
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Nov 08, 2010
Jittery image after around 10 minutes of operation
hi,
i don't think it would be a loose wiring, because you said it comes after a certain time of use and only in one position, it must be a over heating of the sensor that says to the processor in witch position is the cam, or a bad calibration...
did you try to do a reset?
try to reset the cam without moving it from a plane surface parallel to the ground.
if that doesn't work you'll have to send it for repair
cheers
mich
Mar 23, 2014 | Sony HDRHC9 Mini DV Camcorder
Cut video clip does not work
try to format it once using *#7370# the default security code is 123456
Mar 21, 2010 | Nokia N86 8MP Unlocked Dual-Slider 3G...
Window screen is smaller then the monitor. it is on the
For presice adjustments of VGA input run the Auto Ajustment Software on the CD
Additional image quality improvement use the clock and clock pahase controls of the monitor to fine tune the image
Clock increase or decrease the value to minimize any vertical bars or stripes visible on the screen backgroung
Clock phase increase or decrease the value to minimize video distrotion or video jitter
  • allow the monitor to heat up before adjustments
  • use the adjustment pattern application provided ont he CD
  • select OSD menu to select image control and change clock or clock phase
  • Incase of any error restore factory settings select the OSD menu and select factory reset and select yes
Feb 25, 2010 | HP 2159M Monitor
What causes the image on the screen to jitter
Sounds like bad convergence ICs. They are complicated to replace but a good tech should be able to do it for about $100. Let me know how this works out.
hardrocko
Jan 31, 2010 | Mitsubishi VS-70705 70" Rear Projection...
Sony hdr-cx7 image jitters when the cam gets hot
one fix is turning off steadyshot then try putting the camcorder upright(the lens pointing up) for few second until you see the video stabilize, then use as normal but the camcorder will jitter again if handle it roughly. This is just a workaround, i still dont know why it happens, need to send it for repair soon.
Jul 22, 2009 | Sony HDR-CX7 Camcorder
Voice on both end cuts in and out when using the magic jack
Thanks for getting back with me. I have not found a solution to the problem, but have found out what the problem is. The problem is the jitter. The data is not sent out in a constant stream, but is broken up and sent out. My jitter was measured as 201.9 ms, which indicates that it is too unpredictable to sustain a constant flow of data. Now I need to know how to fix that.
Jun 22, 2009 | Computers & Internet
Digital jitter during playback
The random audio/video breakup sounds like a tape path alignment issue. Best done by a repair shop.
Dec 04, 2007 | Panasonic AG-DV2500 DV/Mini DV VCR
Mitsubishi Model # VS-7085
It sounds like vertical jitters:INSTALL VERTICAL JITTER KIT, PART # KIT-V14VJ . If it gets bright and shutdown then:. CHECK THE VALUE OF R9A45 (180 OHM 1/2W RES.),IF OPEN OR INCREASED IN VALUE CHECK FOR A LEAKY OR SHORTED C9A57 (1UF 350V).AT THE CATHODE OF D9A07,ON THE MAIN-PCB.
Sep 05, 2007 | Mitsubishi VS-7085 70" Rear Projection...
Sony DCR-VX2000 Mini DV Digital Camcorder Logo
71 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
