Question about Insignia Digital-to-Analog Converter for Analog TVs
Dtv box it's hook correctly but when i turn the box on i can't see anyth ing, but when i turn it off and it's only on "t.v." then i can see the channels, in other words .. when both t.v. and box are on i can't see anything. How can i add channels that i used to see with the antenna(with good reception).
  • Anonymous Jan 16, 2009
    My tv saids no signal - even though the converter box, antenna have all been connected properly. IN addition my their is a message that saids No Signal.
    The meter in the menu is showing sign level of 0. I don't understand.
I am not sure that this will work on your TV. But I noticed that the converter boxes work on video mode. You have to try video 1 or 2. I already have 2 boxes, different brands and they work perfectly.
Posted on Jan 19, 2009
The box broadcasts through channel 3 thus you have to set your tv to channel 3 to pick up the signal. There is a menu to use once you get a singal to pick up the channels. You may also want to call the 1800 number on the back of the remote, they will wallk you through the problem.
Posted on Jul 09, 2008
I need a 2004 Sanyo T V No remote,hooked to dtv converter box,what menu settings do I use(flat screen,fat back)
when all connected both colour cables and antenna in and out of the desktop box and TV correctlyand both turned on
almost every DTV box will start its menu automatically
and follow the menu promps
chose auto search the channels
Apr 30, 2016 | Sanyo Televison & Video
No picture after hooking up DTV box, Heart Beat sound
Uninstall the DTV Box and scart leads completley. If the box id new take it back to the store and ask them to connect it to one of their TVs or u connect to another TV in your House. The retailer may swap it if faulty. Other than that, Tap the DTV Box 3 or 4 times on the top, blow out all the connections or use a vacuum cleaner this will clear dust and re connect and re install.
Jun 18, 2009 | Mitsubishi VS-50609 50" Rear Projection...
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
Apr 28, 2009 | 1991 Honda Accord
Dtv converter box, no PS2
you need to hook up the ps2 directly to the tv not the converter box the converter box is only for digital Chanel's that will go off air on june 12 but if you have cable or satellite then you don't need a converter box this is only for free Chanel's with they don't requires subscription to cable or satellite your playstation should work with out the box try to hook it up directly to the tv not the box
Apr 28, 2009 | Video Game Consoles & Games
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
After installing the DTV converter box, reception was dropped for most of the stations i received pre-box. now i have added a new antenna. and, i can't get anything through the converter box. connections...
If you have the box connected to the TV using an RF cable to the TV's antenna input, make sure the TV is on channel 3. You should at least see the boxes menu display when the power is on. Try channel 4 if you see nothing on 3. Every box I've hooked up has been on channel 3 by default, but who knows?
If you can, hook the box to the TV using direct video and audio connections, and make sure the TV is set to the correct input.
Unless the box you bought has "RF pass-through" (and if you got your box using a government coupon, it's a sure bet it doesn't) you will notice a marked drop in quality if you try to watch regular broadcasting with the box connected. I've been installing these with a bypass arrangement so people can still watch their analog broadcasts until they go off the air in February.
If the box does in fact have no display when you turn it on and your TV is on the correct channel, your box is defective and should be returned and replaced.
Dec 06, 2008 | Televison & Video
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Emerson Television
With a cable or DTV converter box hooked up, the only channel the TV will find is channel 3 or 4 (depending on how the box is set). Make sure the set is on the right channel and you should be OK. Also make sure the cable is good. If you have several TV's connected to the same source you might have a bad cable or splitter somewhere in the chain. Hope this helps!
Nov 15, 2008 | Televison & Video
I just bought a MAGNAVOX DTV TB100MW9. Before hook-up,we fot channels 4,6,10,20. After hook-up, all I am getting is 4 PBS channels. Why i have a dtv converter box the set up menu does not come up to...
connect the cable box to your tv using the audio/video cables
yellow -red-white
to the same colors on the rear of the tv.
switch the the input to audio/video 1 2 or 3
which ever one works.
Thanks guy9
Jun 17, 2008 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
