Question about Refrigerators
I heard a loud crackling, popping noise coming from the rear of my refrigerator, and smelled plastic burning. I unplugged it and removed the cover, once I could see inside, I plugged it in again and immediately the popping started again. I then saw smoke coming from the overload protector/start relay. Disconnected the power again, and pulled the overload protector. My question being, is it safe to simply replace the protector and switch, or is there something deeper going on here? In a few more minutes I am convinced that the assembly would have caught on fire and do not want to risk this happening again while I am not at home to catch it or worse still, at home asleep. Frigidaire model # FRS23H5DSB8
  • 1,344 Answers
The compressor has an internal ground which is why that happened. You should replace the whole machine in my opinion, because with that kind of problem, I can guarentee that not only is the compressor gone, but the control board in the ref which is wired directly to the compressor has been damaged as well. I've seen this a few times and know its not worth the nmoney to put into the machine.
Posted on Nov 08, 2010
Smoke coming from Refrigerator
Start components or wiring could be getting old and brittle. Take the back cover off. Its usually a cardboard cover with metal screws and inspect/repair the wiring.
Nov 08, 2013 | Maytag Refrigerators
I was watching tv this morning and my set made a loud popping sound and the screen turned black. A red light appeared which read lamp and there was a burning smell. I unplugged the tv waited for a few...
The lamp is most likely needing replacement. Replaceing the lamp is a very easy proceedure on that model.I am pasting a pic where the lamp cover is located on rear cover. Remove the screw and the lamp is behind the lamp door.
Jun 08, 2011 | Mitsubishi WD-57734 57" HDTV
Clicking noise
clicking is propably the main board . it is covered by a 5 x 8 plate . remove it and if it smells like burn smell . the board has failed . and you can here the clicking better when its un covered.. mm
Jan 18, 2010 | GE Profile Stainless Bottom-Freezer...
Suddenly pic went out. Loud crackling and popping heard. Now, Blue indicator and red power light continually flashing. I think lamp. Unit 3 years old
the lamp has blown replace if got instruction book that came with tv shows you how if not got the lamp is behind cover on side or frount cover that comes off by undoing two black screws on back corners (each lower corner) anda sharp pull will remove cover
Dec 13, 2009 | JVC HD-56G786 56" Rear Projection HDTV
Tv made sizzle pop sound and went out
All depending on the models, but i have seen and work on may units with this problem, there are a few large capacitors on the power supply that are sometimes doubly secured with glue, that in turn becomes conductive and causes faults like this. check all the large capacitors for any low or nil readings and with a fine point probe, carefully remove the glue on the and around the caos, and elsewhere if you see any. Good Luck.
Aug 27, 2009 | Apex Digital GB65HD09W 65" Rear Projection...
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Arking and noisey compressor startup. can smell a burning odor after restart
sounds like a bad overload relay assy for your compressor, its attached to the side of our compressor assy if that is what making the noise heres the part number 12002784. but if its burnig and arcing enought o ruin the compressor terminals you may need a new compressor, and depending on when purchased may or may not be covered. new overload relay comes with new compressor if needed
Oct 26, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
