Question about Microsoft Windows XP Professional
When i turn my computer on it immediately goes to a black screen and says insert boot diskette in A:
    Problem Solver:
  • 5 Answers
I think u accedently changed the boot preference tell me which is ur motherboard?
Posted on Nov 08, 2010
  • Game2010 Nov 08, 2010
    shutdown your pc and start it again and try pressing F12,ESC, or delete key it will ask you from where do you want to boot then select your hard disk it should boot normaly.....and dont worry it is nt a serious problem
What is the password for Gateway Essential 566c Desktop PC?
You have to remove the CMOS battery located in your motherboard. Open your desktop casing and look for the battery
May 26, 2014 | Gateway Essential 500 PC Desktop
if you are able to open the pc open it. Remove the cmos battery and turn on the pc and again turn of the pc and install the battery again. if it doesnt work try to locate the cmos jumper on the mother board and clear the bios
Start-up
you may try to bring up your bios screen to see the boot order and then change it if you can....that would be while booting to tap the f2 or f1 key to get that screen ... then check the boot order, if it says position one is diskette, then try to change it...if you can't change it, get the bios updated then flash the bios....that should do it for you. post back your results
Apr 22, 2012 | Dell Computers & Internet
How do i uninstall windows 98 plus from my computer
You simply can not uninstall an OS (operating system), you may have to Format the hard drive itself. If you are upgrading the OS to a version that uses NTFS, like windows xp or higher, a format is suggested. If you have a boot diskette, you can do it that way. If not you can create on using windows 98, but you will need an old floppy diskette and a drive to boot. If you have a newer OS on a CD, simply insert into the computer and follow the on-screen instructions.
If you have a boot diskette(floppy), turn off your computer. Insert the disk and turn on the computer. Let it do its thing, once the diskette loads small programs, you will be able to format the HDD(hard drive).
you will see something like this after its done loading...
c:\
type in format c:
shown like this...
c:\format c:
A message will pop up, saying: WARNING! ALL DATA ON NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
Proceed with fromat? (y/n)
If you are sure you want to erase everything, type in Y. The computer will now format (may take awhile) and will be ready for a new operating system!
Jan 30, 2012 | Microsoft Windows 98 for PC
When i turn on my computer it takes me straight to American Megatrends. What is this? It also says to Reboot and select proper boot device or insert boot media in selcted boot devic and press a key. It all...
Try to check if you have a diskette or usb thumbdrive on your computer. If there is, remove them first then reboot computer again. This is because your system, whichever is the first boot up device doesnt see any system bootup files on it.
Please let me know how this goes. Thank you for using Fixya.
May 12, 2011 | Acer eMachines Black EL1352G-41w Desktop...
A used dell computer, hooked it up and black screen comes up and it says diskette 1 seek failure
Below is a list of possible causes.
Faulty or improperly inserted diskette, incorrect configuration settings in System Setup program(You might be set to boot from the floppy drive. You want to be set to boot from the hard drive), loose diskette/tape drive interface cable, or loose power cable.
If possible please rate this solution.
Aug 26, 2010 | Dell Dimension 8250 PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Black screen with Diskette drive 0 seek failure on it. pressf1 to continue, f2 to enter setup
diskette drive o or disk drive o? f2 to enter bios check boot options to boot on drive o [hdd-0], most boot options go floppy,cd-rom, hdd-0
Feb 04, 2010 | Dell Inspiron 530s Desktop Computer
Formatting problems.
Remove any 3.5" diskette from the diskette-drive in the computer.
Insert the Recovery Disk into the CD-ROM device.
Restart your computer, and *FORCE* it to *FIRST* try to "boot" from the CD-ROM drive, rather than trying to boot from the 3.5" diskette or from your C: drive.
Nov 26, 2009 | Toshiba Satellite A75-S226 Notebook
My HP s123w Slimline Pavilion will not start up. Every time I turn it on, it goes to a black screen stating "DISC BOOT FAILURE, INSERT SYSTEM DISC AND PRESS ENTER" and I do not have the system disc. Any...
Take the floppy disk out of the drive... this sounds like the classic error when the boot order includes the floppy disk first, and a blank or data (not bootable) floppy diskette gets left in the drive.
There could be another type of drive set as bootable. CD's and DVD's don't normally do this - they usually cause a prompt "press any key to boot from CD..." or similar.
You could go in the computer setup and set the hard disc drive to be the 1st in the boot order and also solve this problem.
Otherwise could be your C: drive got damaged somehow. Virus or otherwise.
Jul 07, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Microsoft Windows XP Professional Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
