Question about Microsoft Xbox 360 Console
360 gets power but does not display game - Microsoft Xbox 360 Console
    Problem Solver:
  • 5 Answers
There maybe a problem in a internal chip which controlls the output of the xbox.....it is mainly caused due to fluctuation in voltage or manufacturing defect.there maybe also problem with the lens which reads the cds when you put them in the rom.....take it to showroom or a dealer he will fix it
Posted on Nov 08, 2010
Xbox 360 still Blinking Green without any Display on Screen
Replace the cords connecting to your TV. This usually happens when one or all of the cords get old and need to be replaced.
Apr 09, 2014 | Microsoft Xbox 360 Console
My xbox 360 works fine playing the games that are demos
there might be a short.
other then that i might just think that your power adapter is failing and you need another one.
Dec 01, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
360 will not play any disk
Its getting a kick back from the laser
that is reading the first layer then when it
try's to read the second layer where the game
info is, the single is to weak . The laser is
weak and will need to be replaced .
they cost about 20.00-30.00 if you want
to put it in yourself or you can have a shop
swap it out for 70.00-80.00
if you need any info feel free to ask.
Rob
Nov 19, 2009 | Microsoft Xbox 360 Console
It will come on but cant see see the green cant the the game disp
Make sure this is a xbox 360 game, if it is an xbox game not all of them work on the 360. you can check the list of compatible games on the web site, there are updates you can get for some of them. If this is not the case and the game is for xbox 360 and your other games are working fine, I would suggest that the disk is bad, if you can, try it in a friends machine and see what happens. I hope this helps. Good luck.
Sep 12, 2009 | Microsoft Xbox 360 Console
Xbox 360 says "Please insert this CD into an Xbox 360"
Try to clean out your xbox 360. Or, try to clean the disc with a soft rag and windex. Or, your disc is scratched
Jul 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 Doesn't recognize Xbox 360 games
try going into your settings and family prefrences and if tht doesnt work tht means your game is scratched
Apr 24, 2009 | Microsoft Xbox 360 Elite Console - Black
Xbox 360 does not display any color on any game
definitely sounds like it is a problem with your vga cable. i would suggest trying a different one.
Mar 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 display
This is the common "no video" error which usually comes before you get an e74 or 3rrod like 0102. Try the x-clamp fix and stop by our xbox 360 repair forum if you need more help. Good Luck!
Mar 07, 2009 | Microsoft Xbox 360 Console
Power led is on but no other bars are on
check your cables and the TV your using or just take it back to the place from which you brought it or contact Microsoft. They will send you another 360 free of charge, this includes shipping also
Nov 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
