Question about HP PSC 1610 All-In-One InkJet Printer
It says i have apaper jam. how do i clear thisproblem?
  • HP Master
  • 4,924 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00212225&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=390328
Here are the complete procedure from the support site ..and be sure that you perform the power reset at the final ...it is very important to reset the printer to make sure it remove the error ..
Posted on Nov 08, 2010
We have a lexmark T640 it had apaper jam that we have cleared and it still say check rear door
Check the bad of the printer very closely. There are two flags mounted on the back of the fuser and it is easy to jam them when you are removing paper. You may have to remove the back panel to see what is going on. To remove the back, open the access door and open it part way, when you hit the right spot it will lift out. Next remove the two screws that are just under the slot where the paper exits the fuser. Then remove the top panel that covers the exit assembly. Next you need to press to release tabs near the top of the back panel and then pull the back panel out. You will then be able to see the back of the fuser and be able to check the sensors.
Jul 11, 2011 | Office Equipment & Supplies
How do i fix apaper jam on ahp deshjet 450
The paper path in that model is relatively simple.
Remove all paper from all trays, feeds, etc. If you have a can of compressed air, gently blow into the printer, and blow into all corners.
It is possible that your photo-optic sensors, which tell the printer about paper levels and jams, etc., are covered by paper dust, and blowing it out completely will clear the problem.
Once you have cleared the optics, put some paper into the inbound tray, then print a short but complete page, and see whether it goes through. If so, you have solved the problem.
If not, you must look inside to be certain there is not actually a piece of paper, no matter how small, blocking the paper path.
Once you have made sure there is nothing at all blocking it, power the printer off, wait a minute, then back on, and test the printer again.
If none of this helps, contact HP - they are extremely good about helping their customers with their products.
Good luck,
-a.
Jul 17, 2010 | HP DeskJet 450Ci InkJet Printer
F3 ERROR CODES
This code indicates a fault with the paper tray lift-up motor. F3-12 = tray 1, F3-22 = tray 2 etc. To clear this fault switch off at the power supply and empty the indicated tray of all apaper and jams. Operate the lift up section and then close the drawer with NO paper in drawe. Switch on again and after the machine boots up replace the paper in the drawer. This usually works fine unless there is a serious problem with the lift-up motor.
Feb 19, 2010 | Sharp AR-5320 Black and White Copier
My printer tell me Ihave apaper jammed
Hello sir; If you find any paper inside, remove it , if not check the paper path all the sensor is moving freely.
Feb 07, 2010 | Lexmark Office Equipment & Supplies
Clear paper jam . ho do i clear apaper jam -if I just pull the paper it tears
If your paper will not physically remove then you will need to contact Kodak direct to get a replacement unit. The number for the U.K is 0870 243 0270. For other countries log onto http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm
Oct 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
The paper keeps getting jammed. what does it need? does it need a cleaning or is it normal for it to get stuck often?
Short answer, No.
It shouldn't be getting jammed. Sometimes it's caused form damp apaper and also the paper trays guides are not quite set up correctly.
Aug 17, 2009 | Canon CLC-700 Copier
X3550
What has happened to it? Did it have apaper jam? Let's try a simple reset first.
Turn off the printer and unplug it.
Open the paper jam door and gently roll the paper roller forward until it clicks. close the door.
Leave the printer unplugged for a few minutes then plug it in and turn it on and try it out.
If this does not solve your problem, you may need to reinstall your software. If you do not have it, let me know.
Aug 15, 2008 | Lexmark X3550 All-In-One Printer
Scanning Problem
Did you open up the unit and check really closely near the carriage and the roller? Jams can be so very small!!!
Oct 22, 2007 | Lexmark X4270 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
