Question about Briggs & Stratton Garden
Carburetor for 2.5h.p. briggs & stratton motor - governer spring setup
    President:
  • Briggs & Str... Master
  • 1,545 Answers
I hope these diagrams are of some help.
http://small-engines.com/bsgovernors.html
Posted on Nov 09, 2010
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
How do I refit linkages and springs and in what order on unidentified lawn mower?
Linkage & Spring replacement on a Briggs & Stratton ...
? 7:13
https://www.youtube.com/watch?v=8atnwA4D5lM
Jun 26, 2010 - Uploaded by paisteboy
In this video I replace the two spings at the linkage on the carburetor of my Murray Lawn Mower that has a ...
4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close ...
Nov 24, 2015 | Garden
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
How do I remove the carburetor of a Briggs & Stratton model 287707?
remove the air cleaner assembly,then unscrew the 2 threaded bolts, should be 8mm head visable once air cleaner removed. disconnect fuel pipe,choke and throttle linkeges and backlash spring
Sep 26, 2014 | Briggs & Stratton Garden
21 hp briggs and stratton motor model # 407677 type 0258 trim e1. Motor runs wide open even at idle. Already check the screws on the governor butterflies all are tight. Governor moves freely. Springs...
Its a carb problem. Here is link for the carb overhaul kit - http://www.amazon.com/BRIGGS-STRATTON-797890-KIT-CARB-OVERHAUL/dp/B005F6QHI8
Here is a good walk-through for repairs. The site seems like it has a few bugs. I can't post the direct link to the articles because the pictures don't come through for me and I don't want to give you something that isn't beneficial.
Below is the link to the main page.
http://outdoorpowerinfo.com/repairs/
The articles for your carburetor are: Briggs and Stratton V-Twin 2-Barrel Nikki Carburetor - Part 1 & 2
There are pictures. If they don't come trough try clinking the links on the main page a few times until you get the articles with pictures.
Aug 25, 2014 | Measuring Tools & Sensors
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
New mower 158cc Briggs & Stratton engine April 2010
Um if its new take it back before you damage the govenor then its not warrenty!!
the springs are fine. the metal the the spring conects to on the throtle control sets the high speed. dont play with unless you know what your doing for every ones safety
Jul 01, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton Quattro lawn mower engine. Runs rich and unevenly. Suspect carb and have used sprey carb cleaner. Any suggestions??
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Jun 05, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
1,040 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
